Old 08-31-2016, 01:52 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by loberg View Post
Is there one type of lubricant that is best for this application?
Generic brand Clear Moly available at any auto parts, marine store or wallyworld will do the job.
MICHAEL
Old 08-31-2016, 02:08 PM   #16
2008 27' Safari FB SE
Long Beach , California
Originally Posted by Alumineer View Post
When you think you have the perfect alignment (but before you put your transmission in PARK and let off the brakes), engage the emergency brake. That will keep the TV from moving after you let off the foot brake. As a secondary benefit, many rear brake auto-adjusters are engaged by the emergency brake mechanism, so that you're actually helping the rear brakes stay in proper tune.
I used to do that keep it from moving. But, I thought I read somewhere that because I'm raising the truck so much to connect hitch and then the WD bars, that it wasn't a good idea to engage the parking brake.
If that's not accurate, I'd rather to reinstate the practice of engaging the parking brake. I'm usually in the habit of engaging it anytime I'm parked, regardless of whether it's a hill or flat. Just a habit I've always had.
LBOskiBear is offline   Reply With Quote
Atwood coupler won't latch cwf Hitches, Couplers & Balls 6 08-07-2013 09:31 PM
coupler latch pin SPAN? (measurement please) Astroboy Hitches, Couplers & Balls 4 06-24-2010 10:11 PM
"coupler latch pin size" (help please) Astroboy Hitches, Couplers & Balls 9 06-22-2010 07:28 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Coupler latch when to replace? LI Pets Hitches, Couplers & Balls 6 10-10-2009 03:16 PM
