08-06-2008, 09:35 AM
2001 16' Bambi
2013 23' International
Piedmont Region
, North Carolina
Coupler installation method
I am about to replace the bottom flange plate on my hitch coupler. Somehow the PO bent the back side of it where the safety chains are attached. The coupler is an Atwood part #81911. For those of you who may have the same on your trailer, is it welded or bolted on?
Mine is bolted on the a-frame and in my research to see if there is a specific torque value for the bolts, I have been told that this coupler should only be welded and not bolted on. The coupler is original equipment.
Any ideas???
Thanks, TB
08-06-2008, 09:43 AM
WBCCI 11067 WDCU
1986 25' Sovereign
Atlanta
, Georgia
I replaced my coupler with the Atwood. Three Way campers in Atlanta welded it on and I wouldn't have thought about bolting it on. In fact, I haven't ever seen one bolted to the A-frame.
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
08-06-2008, 08:56 PM
Common Sense
Yep, it needs to be welded on by a professional, certified, welder.
12-28-2008, 03:59 PM
Corona
Any ideas???
Thanks, TB
Couplers are "always" welded, never bolted.
Airstream has "never" installed a bolted coupler since they have been in business.
12-28-2008, 08:11 PM
1967 26' Overlander
Winston Salem
, North Carolina
Hi Pam,
Ask Kevin, he would know.... or you could take it to ODM.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
12-29-2008, 10:13 AM
Greeeneville
, Tennessee
ANDY, Eyes don't lie
This trailer must be a "one off" early Bambi 16 footer. I have seen this trailer with my own, "vision assisted" eyes. It has never been modified since it left Jackson Center. IT WAS bolted on-- even though JC can't find any records of ever having built this unit. It seems AS does a lot of experimenting, even today.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
12-29-2008, 10:27 AM
Corona
Originally Posted by Silverhobby
This trailer must be a "one off" early Bambi that I have seen in person. It has never been modified since it left Jackson Center. IT WAS bolted on-- even though JC can't find any records of ever having built this unit. It seems AS does a lot of experimenting, even today.
If that's the case, I would do 2 things quickly.
1. Get a new coupler, and while your at it, increase the ball size to 2 5/16", instead of the original 2 inches.
2. Find a good welder to install it, prior to your next trip.
12-29-2008, 04:49 PM
2001 16' Bambi
Piedmont Region
, North Carolina
coupler fix
Thanks for the concern about the coupler. I knew it was an odd bird so I did my research and got it all straight.
The coupler that was bolted on has long ago been replaced with a new one that is properly welded on according to the coupler OEM instructions. No need to increase size as the original was a 2 5/16" with correct weight rating, just a different part #. Towed about 1700 miles and lived in for 3 months since then, all is fine.
Happy New Year,
TB
