Old 09-27-2010, 08:35 AM   #1
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Question Coupler Adjustment Freeplay
Since the trailer was setup by an SOB dealer I found that there seems to be a lot of verticle free play when the coupler is latched. The trailer passed state inspection so I assumed that all was well.
I looked expecting to see a nut adjustment and on an airstream and there doesn't seem to be one.
What amount of free play should there be vertically? And is there an adjustment for a 1976 Argosy coupler?
arcamedies is offline   Reply With Quote
Old 09-27-2010, 08:55 AM   #2
richinny's Avatar
2011 34' Classic
are you using the correct ball size?
Ricky
Old 09-27-2010, 09:00 AM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Almost none.
Check the ball size. Should be 2 5/16
A dealer sent me home once with a new trailer on a 2 inch ball. After a noisy ride home, I found that the coupler on trailer was a 2 5/16 inch.
Regards,
Ken
Old 09-27-2010, 09:03 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
There shouldn't be any up and down play to speak of. Check to make sure that you are not using a 2" ball.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 09-27-2010, 09:04 AM   #5
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Ball size
They installed a 2 5/6" ball but coupler locking part may be worn???
Old 09-27-2010, 11:50 AM   #6
richinny's Avatar
2011 34' Classic
yes they can be worn. replacement parts are available. check with your favorite rv supplier.
http://www.airforums.com/forums/f44/...-do-51054.html
Ricky
Old 09-27-2010, 12:11 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You can find an original style latch here 2-5/16" Marvel Coupler Repair Kit
You may want to check the coupler itself - check the inside forward surface for wear.
Old 09-27-2010, 03:08 PM   #8
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
arcamedies -
i think that's what the captain of the titanic said as they steamed out of harbor.
alway check and re-check yourself if you think something is amiss.
we had our AS registered w/o the inspector even seeing if the lights worked or checking to see if the hitch was secure.
you are doing the right thing by asking the forum. there's a lot of good people here - all willing to help.
good luck and safe travels
az-streamer
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Coupler lock BCMC27 Hitches, Couplers & Balls 2 01-14-2010 12:00 AM
Coupler wear: what to do? allanrd General Repair Forum 4 05-07-2009 09:59 AM
Coupler Question at_wanderer Hitches, Couplers & Balls 4 06-08-2007 03:55 PM
Thermal coupler help. rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-23-2005 12:12 PM
coupler lock rcaldwel Hitches, Couplers & Balls 5 01-10-2003 07:23 AM
