Old 07-16-2003, 09:55 AM   #15
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Hubbys are handy huh Steph?
They can also be trained to jump up and down on the hitch while you disengage. Cusswords optional.
Rog0525 is offline   Reply With Quote
Old 07-16-2003, 10:10 AM   #16
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
WD-40 IS great to use as a non stripping cleaner of the old gooey gooky grease. Use lots of it and a old rag and it will almost polish up. Then you can re-grease.
As to the concern on the coupler wear, the latch is where most of the pressure seems to be, and it is a simple matter to drive out the pin and replace the pawl that locks the trailer to the ball.
It even rhymes!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-23-2003, 12:30 PM   #17
Question 4-mil Plastic?
Any other comments on this? It sounds good, but does it really supply a "lubricant" or slip surface?
How long have you been doing this?
Elliott B
ElliottBartlett is offline   Reply With Quote
Old 07-23-2003, 01:00 PM   #18
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Pardon the digression but while we are discussing balls, lube, etc.... I have another problem that I sort of found a solution to because the hitch ball was stuck. Lifting the whole thing is a little too much for me sometimes, especially now that I have Enkay mudflaps that also weigh down the hitch bar.
So, what I have been doing is leaving everything attached, releasing the tension on the WD bars and pulling the pin on the hitch bar/receiver and sliding that out. I leave everything hanging from the trailer hitch.
Practicing has made this as easy as aligning the ball with the hitch almost.
I use the rod/pipe for raising and lowering the WD bar chain mechanism to sit the bar on when I aim for the receiver hole. It seems it wants to flop down if I don't.
Kistler
Kistler is offline   Reply With Quote
Old 07-26-2003, 08:40 PM   #19
Rog0525's Avatar
Images: 11
WTG Kistler. It ain't rocket science. If it couples, it will also uncouple., although it is sometimes fun to have someone jump up and down on the tongue hollering obscenitiess.
Kinda wakes up the campground too.
Rog
Old 07-27-2003, 07:27 AM   #20
Kistler's Avatar
2002 25' Classic
Jumping on the bumper in my case could cause a big body shop cost....I think the bumper is plastic.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Old 10-02-2003, 01:00 PM   #21
I had the stuck ball problem after I changed from a Jeep to Suburban tow vehicle.
My Reese hitch has a spacer "stud" between the part that goes into the tow vehicle and the part that the hitch screws into. This already had a couple of the supplied washers under it. I added one more washer under the stud and since then the hitch comes off and on much easier. The spacers change the angle of the ball and how it fits into the trailer.
Elliott B
silly ball height question. AV8 Hitches, Couplers & Balls 7 11-09-2003 05:32 PM
Help-Hitch Ball problem Chitown AirStreamers Hitches, Couplers & Balls 4 07-22-2003 12:35 AM
Multi- ball Set Up niftypkg Hitches, Couplers & Balls 3 04-10-2003 09:02 PM
coupler lock rcaldwel Hitches, Couplers & Balls 5 01-10-2003 07:23 AM
Ball Size on '70 Caravel? MattyBoy Hitches, Couplers & Balls 3 01-06-2003 08:03 PM
