Old 08-14-2013, 05:51 PM   #1
2014 Interstate Ext. Coach
Monroe , Washington
Chrome worn away on hitch ball
Hello,
I have noticed some wear on my hitch ball, where the chrome has worn away and there is some pitting. I have attached pictures. So...
1) Should I replace this ball or may I continue to use it?
2) Is this normal and reasonable wear, or is there something wrong with my setup?
Thanks!
P.S. The ball has about 15,000 miles.
I clean & lubricate the ball using Reese Hitch Ball Lube (Reese #58117) before trips and every few days while on the road.
If it matters, the rig is
-- A 1/2-ton pickup (5400 pounds)
-- A 16-foot International (4000 pounds, 475-pound hitch weight)
-- A weight-distribution hitch (with round, 600-pound spring bars)
ID:	193182   Click image for larger version
coder is offline   Reply With Quote
Old 08-14-2013, 06:04 PM   #2
1974 Argosy 20
Kooskia , Idaho
looks normal to me. The thin chrome applied to a ball is mostly for show in the store, and has no real useful purpose.
I do replace my hitch ball every 75 to 100 thousand towing miles, just in case some internal cracking has occurred.
I would check your coupler internally after 30 to 50 thousand miles. My Argosy 20 did develop cracks in the inner cup which I discovered quite by accident. I cleaned the built up grease off and there they were, although no failure occurred, I was glad to find out prior to one.
Old 08-14-2013, 06:09 PM   #3
dznf0g's Avatar
Oswego , Illinois
Normal, in my experience.
-Rich-
Old 08-14-2013, 06:13 PM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
On cheaper chrome plated hitch balls, the plating will flake off. This does not affect the integrity of the ball. If you don't mind the look of it, continue to use it.
There is some argument regarding lubing vs not lubing a hitch ball. Some say that the lube attracts dirt which contributes to premature wear. If you clean and lube the ball and keep the trailer attachment clean you shouldn't have a problem.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-14-2013, 06:16 PM   #5
1981 31' Excella II
New Market , Alabama
I would use some grease with moly in it such as wheel bearing grease. I usually use spray on lithium grease since it is easy to apply. The ball looks fine. It won't hurt to rotate the ball every one in a while.
Perry
Old 08-14-2013, 06:17 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You must be using your AS!!??? Shame on you!!
Get a shiny ball to put there when not towing.
How about a ball cover?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-14-2013, 06:18 PM   #7
TinShack's Avatar
2005 28' Safari S/O
Also, when the chrome wears off, people get concerned and go buy a new hitch ball. Great for sales!
Steve
Old 08-14-2013, 06:24 PM   #8
withidl's Avatar
2002 31' Classic
Houston , Texas
You could source a stainless steel ball and there would be no chrome to wear off.
withidl is offline   Reply With Quote
Old 08-14-2013, 08:06 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Someone could make a Flamingo one.
Channing
WBCCI# 30676
Old 08-14-2013, 08:37 PM   #10
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I ashamed to say my hitch ball has more chrome than yours. My excuse, new to Airstreaming. Can't wait to get the mature look of yours.
kscherzi is offline   Reply With Quote
Old 08-14-2013, 08:49 PM   #11
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
I use Real Magic on mine. It's a very light lithium made for fishing reels and line.
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
Big C is offline   Reply With Quote
Old 08-15-2013, 06:12 AM   #12
1981 31' Excella II
Replacing the ball occasionally is good insurance. Everything has its limits.
Perry
Old 08-15-2013, 06:27 AM   #13
2010 25' FB Flying Cloud
Davenport , Iowa
A closer look, is that 2 piece ball? If so, I would replace. From the picture the edge of the base appears bent, or is that the way the picture was taken?
Airtandem is offline   Reply With Quote
Old 08-15-2013, 06:32 AM   #14
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Flat spots so you can use a wrench on it.
Wayne&Sam is online now   Reply With Quote
