Old 08-15-2013, 08:39 AM   #15
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
I used to use wheel bearing grease, which works fine. Clean it off and re-grease it at times. Then started using a couple thicknesses of aluminum foil applied every time I hitch-up. Seams to work just as well and not as messy. Do periodic inspections of my hitch assembly- -no problems so far.
Most important thing is to do regular inspections.
JStanley is offline   Reply With Quote
