Old 12-21-2015, 07:24 AM   #1
2016 25' Flying Cloud
Holly Springs , Mississippi
Choosing the right shank?
Does anyone have written down the distance from the ground to the top of your FC 25 hitch? I need to order a hitch and shank for my soon to arrive trailer, and want to be sure I select a shank with enough drop.
I don't have access to another 25' FC, so wondered if someone could help me out with your dimension? All I need is to get in the ballpark; I'll fine tune it when the trailer and TV are together.
Thanks!
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 12-21-2015, 07:38 AM   #2
Gainesville , Florida
Used to be around 19 inches on most AS, but others will have the correct amount.
Old 12-21-2015, 07:38 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Wally 'sez 17 3/4" in the OM.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-21-2015, 10:12 AM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My 2008 Class 25fb is about 21" from the lower lip of the tongue to the floor when level. The ball looks about 23". My AS has 15" rims.
Kelvin
Old 12-21-2015, 10:31 AM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
13 31 classic is level with about 22 inches....
Old 12-21-2015, 05:09 PM   #6
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Why the fuss????
Just level the damn thing and measure from the ground to the top of the ball socket!
MelGoddard is offline   Reply With Quote
Old 12-21-2015, 05:18 PM   #7
Talking
Thanks!
Just level the damn thing, and measure from the ground to the top of the ball socket!
Old 12-22-2015, 05:22 AM   #8
Question Measuring what you don't yet have.....
"I need to order a hitch and shank for my soon to arrive trailer, and want to be sure I select a shank with enough drop."
Just read the OP's original post before planting your damn response ......
PFC
RLC
Old 12-22-2015, 05:28 AM   #9
Agree!
Old 12-22-2015, 06:39 AM   #10
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
New Airstreams with 15" rims are currently running 21" but the axles will settle a 1/2" in the first few thousand miles. 19' Airstreams are 1" lower.
When you are ordering a shank get one that keeps the ball as close to the bumper as possible. For a standard height Eaz-Lift has the best one. If you need an extended drop there is not really a good one on the market. We have ours built by a very capable machine shop in order to get a good one.
What is your tow vehicle and which hitch system are you using?
Andrew T
Name:	Extra Drop Shank.jpg
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-22-2015, 08:14 AM   #11
Hi Andy,
I'm using an F-150 + FC25 and will be using the Eaz Lift 1400# you suggested. I was just trying to do a bit of "prevent defense" and assess whether the Eaz Lift shank would have enough drop for this combination. If it didn't, and the TT and hitch were on-hand, I'm in trouble!
You think the Eaz Lift 48120 shank will have enough drop?
2016 FC 25' FB twin
Old 12-22-2015, 09:50 AM   #12
It should be close enough to get you on the road and to an rv place for the correct size. My local dealer has an assortment on hand.
Old 12-22-2015, 11:24 AM   #13
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 12-22-2015, 11:50 AM   #14
I meant the shank should be close enough.
Right sealants on the right sections BoldAdventure Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-22-2014 11:09 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
The right acid works with the right applic got polish Cleaning, Stripping & Polishing 1 07-17-2008 08:50 PM
Need a Weight Dist. Shank with more drop!!! JeepinAudiophile Hitches, Couplers & Balls 11 07-19-2004 12:30 PM
Choosing the Right Model Airstream MH grassgd Airstream Motorhome Forums 13 01-06-2003 09:59 PM
