Old 06-08-2006, 02:16 PM   #1
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Check your Chevy Factory Hitch
I got a call today from my good friend ZoominC6. He knew that I had a 2005 3/4 ton Chevy Suburban. According to his Airstream dealer there has been several cases where the weld on the receiver has come loose. Well on ZoominC6's advice I checked my receiver and it did look like the weld on one side had come loose. I went straight to my Chevy dealer and he is putting a new receiver on while I wait.
Has any one else out there had their Chevy receiver replaced? Or have you checked your factory receiver and seen any unusual rust at the weld locations?
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 06-08-2006, 04:26 PM   #2
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
I had heard of this happening on older (pre 2004.5 models) and check mine frequently but have not seen broken welds or cracks. I have just upgraded to a Hensley with the new trailer and wondered if it was putting any additional stress on the receiver. Can you describe where yours was broken in greater detail?
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 06-08-2006, 06:16 PM   #3
FiveGreers's Avatar
Crestview , Florida
Wow, thanks for that bit of info. I'll go check ours, and will continue to do so from now on.
Minya and the kids
2005 22' Safari-
...lost her in the divorce-
Would like another (Airstream), please!
FiveGreers is offline   Reply With Quote
Old 06-08-2006, 06:16 PM   #4
Road Ruler's Avatar
Images: 38
Read all about it..... in pages of detail.
http://www.trailerlife.com/cforum/in...d/15852601.cfm
OR...... just dump the Gm junk and replace it with a receiver that is up to the task, whatever that may be.
Old 06-08-2006, 06:31 PM   #5
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
On sound advice we're dumping our GM hitch for a Reese Class V Titan. Our Hensley was installed this morning and our technical staff at Roger Williams Airstream advised us that the Hensley puts additional stress on the hitch. We're going to a Class V and reducing down to a Class IV shank, having it welded on the back side to the receiver. We had no issues with the GM hitch on our '04 using the standard weight distribution hitch. We closely monitored the GM hitch on that truck for cracks in the welds and any rust in those areas after hearing there were issues with the GM setup. With the addition of the Hensley, this change seemed the prudent thing to do for peace of mind if for no other reason.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 06-08-2006, 08:33 PM   #6
silverback's Avatar
2006 28' Safari SE
Mine says it is a class V Talon, has the plate in the middle and looks fine.
Zoomin,
Why are you reducing yours to a class IV shank?
Ken
4CU Charter Member
Old 06-08-2006, 08:46 PM   #7
ZoominC6's Avatar
Colleyville , Texas
Ken,
We're following instructions of the Hensley installer and I can only assume it's because the Hensley is Class IV rather than the larger Class V setup. I believe a Class V is larger than the 2" X 2" Class IV but someone familiar with the heavier rigs can correct or confirm this. I'm happy to have the pros advise me with this Hensley rig and glad that I didn't install it myself or I'd still be messing with it. As it was, it only took a couple of hours at the most.
Old 06-13-2006, 11:13 AM   #8
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Ken
Ken,
My receiver was not broken, only rusty on the right side where the receiver support was welded to the cross tube. It looked like the weld might have came loose or was not welded correctly from the factory. I do have a Hensley and will continue to watch the same place very carefully in the future. We did tow 200 miles this weekend and I have not seen any change in the new factory hitch.
Abe
Hensley Hitch
Old 06-13-2006, 03:04 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Ken,
IIRC some Class V hitches use a 2.5" square receiver. Putnam uses 2" square, same as the Class IV, however you do have to be careful that the drawbar is heavy enough for the load being carried. But I have found that the vehicle that the hitch is attached to is usually the limiting factor.
Aaron
WBCCI #XXXX AIR #2495
Old 06-13-2006, 03:27 PM   #10
jcanavera's Avatar
Fenton , Missouri
Images: 143
We're going to a Class V and reducing down to a Class IV shank, having it welded on the back side to the receiver. .
FYI, Hidden Hitch builds a Class V receiver that doesn't require a reducer. One of the reason's I went with the Hidden Hitch when I needed to upgrade my van's receiver due to the heavy hitch weight of my slide out.
Jack
Jack Canavera
STL Mo.
AIR #56
Chevy Express vs Suburban alan Tow Vehicles 8 07-27-2003 03:38 PM
Chevy Astro/GMC Safari as tow vehicle generalsparky Tow Vehicles 19 03-05-2003 09:15 AM
hENSLEY HITCH TCP4 Hitches, Couplers & Balls 20 10-30-2002 05:44 AM
Banks PowerPack for 7.4L Chevy LTD93 1969 Overlander 6 09-24-2002 05:53 PM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
