Old 06-15-2008, 10:34 PM   #1
WyoRacerX's Avatar
2008 16' International CCD
Cheyenne , Wyoming
Changing TVs and switching wd hitch arms to new TV
I'm looking at upgrading the TV from a Tacoma to a Tundra. Do I need to change out the weight distibuting hitch load arms or can I keep the same arms and just adjust for proper leveling by selecting the correct links to level out the load?
B
WyoRacer X
'08 16' Bambi International
living west of Cheyenne.
Blog
WyoRacerX is offline   Reply With Quote
Old 06-15-2008, 10:49 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Any time you change TV's you need to go through all the adjustments for the hitch. That includes ball height, ball angle and chain tension. Basically, you start all over and set the hitch up from scratch.
Richard
Old 06-16-2008, 12:41 AM   #3
_
hi wyo...
MOST of the time the SAME w/d bars (spring bars) can be carried over with the hitch...
assuming the bars are already correct for the tongue mass...
the proper set up may include more or less tension on the w/d bars...
this is BEST determined with weight measurements for the axle loads b4/after adjustments...
or measurements of tv stance pre/post.
the new tv will likely have a DIFFERENT receiver box height....
so a new stinger (ball drop bar), with a different drop may be needed...
unless the current stinger is adjustable to the new height....
as suggesting the entire set up process must be redone and dialed in...
but your up grade to tundra notion,
is a good one.
cheers
2air'
Old 06-16-2008, 07:34 AM   #4
WyoRacerX's Avatar
Cheyenne , Wyoming
Thanks 2air, I do have an adjustable 'stinger' so hopefully it'll adjust to the 18" required after mounting on the higher Tundra. I'll have to find a shop around here with a torque wrench so I can properly tighten the bolts back on after adjustment.
WyoRacer X
Blog
NOTICE: Switching to a new network Andy R Forum Admin, News and Member Account Info 23 08-26-2007 04:39 PM
Switching to new e-mail address Devoman Forum Admin, News and Member Account Info 4 03-09-2007 12:08 AM
Switching out cabinets dogstayplay General Interior Topics 5 04-05-2005 09:23 AM
need opinion - switching out tanks kbryner1 LP Gas, Piping, Tanks & Regulators 7 05-24-2004 08:06 PM
Switching to Diesel? silverback On The Road... 44 11-25-2003 01:30 PM
