Old 11-24-2009, 08:25 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
changing hitch size
Any reason to change the smaller 2in. hitch to a larger 2 5/16 on a 65 trailer?
Difficult to do?
bwaysteve is offline   Reply With Quote
Old 11-24-2009, 08:27 PM   #2
SteveH's Avatar
Common Sense , Texas
If the original hitch was in bad condition, when I had it changed, I'd change it to the larger 2 5/16". Generally speaking, they are rated for more weight. Any competent welder can do it.
Old 11-24-2009, 08:34 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Difficult to do?
Keep in mind your trailer is not as heavy as the newer trailers. So unless you there is something wrong with the hitch that can't be repaired put that upgrade down a little lower on the todo list.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-24-2009, 10:43 PM   #4
Difficult to do?
Couplers and especially the coupler locking fork, do wear.
Obviously the 2 5/16 inch coupler is far superior than the 2 inch.
Since the coupler is the "only" link between the trailer and the tow vehicle, if you have any doubts, replace it, if for no other reason than peace of mind.
Depending on the mileage, coupler forks are replaced by many owners.
Hitch size Jim Sease Hitches, Couplers & Balls 16 10-12-2010 10:04 AM
Right size WD hitch????????? purman Hitches, Couplers & Balls 4 10-24-2008 09:41 AM
Changing TVs and switching wd hitch arms to new TV WyoRacerX Hitches, Couplers & Balls 3 06-16-2008 07:34 AM
Changing out faucets- what size copper piping? charlie tuna Fresh Water Systems 10 08-22-2006 11:02 AM
Hitch ball size Argosy27 Hitches, Couplers & Balls 1 05-23-2006 05:53 PM
