Old 02-04-2014, 11:35 AM   #1
cincinnati , Ohio
Chains? Which ones? What length?
Towing newbie here trying to be ready to buy and pull my trailer from the sale.
I'm looking at trailers with dry weight under 4k. I have a factory 3/4 hitch. What size and type of chain should I get. I think I should get two and each should have the capacity for a loaded trailer. But what length? 36 inch and tie off on the hooks on the hitch or 72 and tie the chain off on itself?
RhinoWW is offline   Reply With Quote
Old 02-04-2014, 12:04 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Unless you're buying a very old Airstream or one that's been damaged, it should already have safety chains installed. What sort of trailer are you looking at?
EDIT: Oh, and re: attaching the chains to your tow vehicle: I use hooks with a latch at the end of the chain and hook those to the holes for that purpose in my receiver.
— David
Old 02-04-2014, 02:24 PM   #3
cincinnati , Ohio
I am focused on Argosys from the 70s. Looking at a 78 20 footer and a 74 24 footer in the near future.
Old 02-04-2014, 02:53 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
All 3 of my Argosies already had safety chains ('73 26' parts trailer, '75 24', '76 28')... I think someone would've had to break or intentionally remove them for you to find one without, but taking hooks or bolts to use to hook to your truck might be wise. Come to think of it, that's one of the things I didn't take on any of the rescue missions. I did have baling wire, though!
— David
Old 07-31-2014, 10:01 PM   #5
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Use them!
Just make sure you use them, unlike this guy who we saw pulling a horse trailer today. That horse would have had a very unpleasant 70 mph ride if something had gone wrong! Not to mention the other drivers on the road. Hope he made it safely to wherever he was going.
Name:	No chains.jpg
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-31-2014, 10:32 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Get "proof" coil chain. They are welded links and load tested. Each chain should be able to support weight of trailer. Should be of sufficient length to CROSS from left to right and provide a "cradle" to catch the tongue should things go north. The chains should also not bind in turns.
Using proper hooks with the retainer clip/ spring latch are recommended. Less likely to be shaken off.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Trailer length G-willy 1959-69 Tradewind 11 11-04-2011 03:49 AM
Trailer length? G-willy Airstream Registry Discussions 0 10-31-2011 11:31 AM
Hitch, chains and tongue. ShawnG17 Hitches, Couplers & Balls 1 07-19-2011 01:05 PM
Breakaway cable length? oceantribe Brakes & Brake Controllers 12 01-10-2011 04:18 PM
