Old 04-09-2018, 05:58 PM   #1
Luling , Louisiana
Chain brackets and propane cover?
We have a dealer installed Reese WD hitch w/ dual cam sway control purchased with our 2017 25' AS. The spring bar chain brackets don't allow the rear side of the propane tanks cover to rest on the A-frame. So the cover sits misaligned. Can the brackets be repositioned an inch or so back to allow the cover to sit properly? I think this might be a common situation with folks who have this type hitch and i would appreciate learning what they may have done.
retiree is offline   Reply With Quote
Old 04-09-2018, 06:04 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Sue they can.
2012 Dodge Durango Hemi/AWD
Old 04-10-2018, 08:05 AM   #3
2017 23' Flying Cloud
Bartlett , Tennessee
I have the same setup you do, but with no interference. I am currently out of town, but will be home tonight. Tomorrow AM, I will take a photo of mine and post it for you.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 04-10-2018, 08:20 AM   #4
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
I have the same problem with the ProPride jack stand bases on our 27fb, probably worse, since those bases are pretty big. I fashioned shims or risers for the front mounting screws of the propane bottle holder that mounts to the trailer frame. With longer mounting screws ( or drill and tap frame for bolts like I did), you can re-mount that base level.
Hope this makes sense and helps.
ShinyPete is offline   Reply With Quote
Old 04-11-2018, 11:38 AM   #5
Here is my Reese Strait-Line WD hitch with Dual Cam installed on my 2017 23FB Flying Cloud.
Old 04-19-2018, 05:55 PM   #6
2007 25' Safari FB SE
Aiken , South Carolina
Chain bracket and LP cover
So, I am trying to install the Reese Dual Cam sway control on my 2007 25FB Safari. The picture that you posted seems to show that the chains are not vertical . They make a big deal of that in the instructions. I can't get the chain brackets far enough forward to make the chains vertical because of the LP tank cover. Any suggestions? Thanks
awkirch is offline   Reply With Quote
Old 04-19-2018, 07:39 PM   #7
2016 20' Flying Cloud
Oliver , British Columbia
I made a little cutout in bottom of propane cover. hitch brackets aligned vertical and no interference with propane cover.
2016 FC20
2018 Jeep Grand Cherokee
mjmstream is offline   Reply With Quote
Old 04-19-2018, 08:16 PM   #8
My chains are not vertical, but they are not far off of vertical. I didn't do the install, the dealer did, so I was unaware of that provision. It has worked for a year, so I am going to leave it as is. I really don't see that small a deviation being a big problem. The purpose of the chains is to hold the cam at the proper height. If you have enough of a deflection, it will put a lot of force trying to slide the bracket forward, but that small a deflection won't create a huge lateral force. Even if it does, all it will do is bend the propane cover and slide the brackets to the point where the chain is vertical.
Motorhome timing chain and gear question Belle Classic Motorhomes 22 03-09-2017 01:20 PM
Weight distribution brackets and the Propane gas line along the Otterbrawten Towing, Tow Vehicles & Hitches 16 05-11-2016 12:37 PM
Wanted- belt buckle and key chain SebasSF General Motorhome Topics 1 01-14-2015 08:12 PM
Need Cap and Chain for 1969 Holding Tank ? tdoescher 1965-1969 Sovereign 1 04-27-2009 11:54 PM
