10-12-2015, 09:38 AM
2005 19' Safari
2010 30' Flying Cloud
Langton
, Ontario
Cat scale weights
10-12-2015, 09:51 AM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Very nice looking set up. Like the commercial storage end of your truck.
Hittenstiehl
10-12-2015, 10:00 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
I'm thinking you need some more weight on the steer axle. I'm sure some of the pros will chime in.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
10-12-2015, 10:09 AM
2005 19' Safari
Langton
, Ontario
The truck is used for our dogs. Three on each side plus storage for training equipment, clothes, food etc.
10-12-2015, 10:14 AM
2005 19' Safari
Langton
, Ontario
That's what I was thinking but it's a struggle getting the one link on the wd bars.
10-12-2015, 10:40 AM
2015 27' FB International
Howard
, Ohio
You should be shooting to recover more front axle load with WD. From 50% to 100% depending on who you take advice from. I'd try for close to 100% recovery. To get more links on, hitch up and then use your AS tongue jack to lift the coupled rig as high as possible. Should be "easy" to get 2-3 links on there. Try it with 2, drive around, weigh then try with 3 and repeat. Confirm you are not exceeding axle loads (nameplate inside drivers door), assuming neither gives you trouble, pick the one that drives best. You may need to adjust your hitch setup to correct for level - with more WD applies you will tend to be more nose up.
10-12-2015, 11:02 AM
2005 19' Safari
Langton
, Ontario
We do use the tongue jack to help to attach the wd bars. With our old 3/4 ton truck attaching to the 3rd link was easy. With the new 1 ton it's difficult to get just one link hanging down.
10-12-2015, 11:05 AM
2005 19' Safari
Langton
, Ontario
Max axle loads are 5600lbs for the front and 9375 for the rear.
10-12-2015, 11:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I would try for another 200lbs to the front, with the rig,(AS&TV) level at that setting.
But.....with the HD, 2500,D-Max a lot rides on how it rides. Put miles on each setting & chooze the one that werks best for you.
10-12-2015, 01:18 PM
2020 Classic 33
Box Elder
, South Dakota
GM suggests a 50% restoration. ThevGM suggestion is based on measuring the height of the front fender (ground to bottom of the fender trim. Restores As mentioned how does it drive? From a weight standpoint your 1/2 link is pretty close to a 50% restoration of weight.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NŘVPN
10-12-2015, 03:20 PM
2005 19' Safari
Langton
, Ontario
Unless my math is wrong 1/2 link is 44% and 1 link is 55%. Both set ups seem to drive ok. Can it drive better? What's best for the trailer?
10-12-2015, 03:53 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
...best for the trailer?
The AS doesn't really care as long as it's level and it's axle & tire ratings haven't been exceeded.
10-13-2015, 04:33 PM
2005 19' Safari
Langton
, Ontario
Same couple of rivets by the door seem to pop occasionally. I thought this maybe because of the hitch setup.
10-13-2015, 06:09 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Do you have helper springs or any suspension mods? Trailer wheels balanced? Running gear shake a common cause.
600/800lb WD bars would help soften the rear suspension ride.
10-13-2015, 09:33 PM
1999 34' Excella
Hillsboro
Ah... that is interesting information... which rivets 'pop'? When?
Several 'tire stores' around here say 'Oh, we do NOT balance TRAILER tires'... but I make them do it... and I watch them.
Next, I put 'Centramatics'.. which smoothed out the ride tremendously.
I have lost NO rivets... since then. running 1400# bars on ProPride (previously EzyLift) system.
On 2012 Dmax, 2500 HD I restored 'steer axle' weight so that the front was at the same height as without AS attached.
Peace and Blessings..
Channing
WBCCI# 30676
10-14-2015, 12:39 PM
2005 19' Safari
Langton
, Ontario
Thanks, new tires are in order for the spring and I'll start researching Centramatics
