Old 01-11-2011, 12:53 PM   #43
JFScheck's Avatar
Rockville , Maryland
Images: 33
Guilty as well....
Congrats again - its all down hill after the first big "bump" in the road...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 01-11-2011, 02:10 PM   #44
1988 34' Excella
Troy , Texas
When I purchased my new truck...had the same problem....one thing to check ...make sure you raise the tongue of the trailer where the weight of the trailer is neutralized with the shaft of the hitch...doesn't seem like the coupler is releasing...when you raise the coupler latch push forward...(away from trailer)...the blocks under the jack helps only is the coupler is releasing....if this doesn't work...make sure the wheels are chocked where the trailer will not roll in either direction...if you have the trailer lifted to neutralize the weight of the trailer free of the truck hitch...take out your shank hitch bolt and drive off the hitch...make sure someone is watching the hitch and that it is releasing from the truck receptible....you will need an extention shank for your weight distribution hitch....also check and see if you have the proper size ball for your trailer...hope this helps....
excella88 is offline   Reply With Quote
