Old 01-08-2011, 09:05 PM   #29
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
http://www.barkermfg.com/superjackpg4.pdf
Old 01-08-2011, 09:14 PM   #30
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Good luck with it...and above all, as several have said...BE CAREFUL...this could lead to more than a bruised ego ... By the way, we all have situations we can't figure out right away once in a while...you'll get it done eventually and you'll know what the reason was...the main thing is to keep yourself safe.
TB & Greg and Abbey Schnauzer
#3954
Old 01-08-2011, 09:16 PM   #31
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Originally Posted by LawChick
Where is it?
They all don't have a manual crank.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-08-2011, 09:38 PM   #32
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, you have been given some good information. I will explain it a bit differently. But first you must have power to the tongue jack. Lift the trailer high enough for the spring bars to easily come off. Remove the spring bars. Then lower the jack all the way down until the jack foot starts to come off of the ground or where you see there isn't any pressure on the hitch. Now you can slide the latch foreward and lift the handle upward to release the ball. If you have upward pressure on the ball and coupler, you won't be able to release the coupler latch. Now raise the tongue jack again and it should lift off of the ball.
I know that on my set up, if there is pressure towards the front or rear on the ball because of the trailer or tow vehicle, the ball will bind and not want to disconnect. Also if there is pressure from the tongue jack, in a lifted form, the latch will not move.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-09-2011, 12:53 AM   #33
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Sounds like the ball is binding up or the safty latch is hanging up. It might be possible to have the trailer set at a good height, pull the pin on the truck hitch and pull the truck off the receiver. Not recommended, Pretty scary but doable if you study where the truck will rebound to. Then study why the ball is stuck to the trailer. Might be a good trick to know if you need to abandon the trailer in a real quick situation.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-09-2011, 08:48 AM   #34
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Possible stripped gears
When we brought our Airstream home for the first time, we found that the power jack had stripped the gears inside the power head and would not raise the trailer. There were obvious noises from the powerhead that sounded like gears missing a tooth or three or four.
If yours is a Barker jack like ours, taking the power head off the jack gives access to the manual crank. The link Melody Ranch send you is the instructions for everything associated with that jack. Makeshift tool can be used to turn the mechanism, if the original crank isn't with the trailer. It took me a couple of days to find ours; it isn't very big.
Good news is that the gears are available to fix the powerhead, and they're not hard to replace. Do the "timing" instructions carefully when you put the powerhead back on the jack. The gears strip if the jack reaches its mechanical stop before the limit switches stop the electrical motor. It's supposed to reach the electrical limits first.
Good luck.
Old 01-09-2011, 11:17 AM   #35
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Morrilton , Arkansas
Images: 55
This is Ray, well - it came apart finally (actually rather easily too). The trick was to attach the shore power and use a concrete block to gain a little height. I also made sure to push the latch forward before pivoting it up. The jack made that wonderful whir/whir/whir sound all the way up (on the umbilical it would just go silent after a moment or two). The jack lifted the trailer a lot faster on shore power too. The ball came loose with a sort of pop noise, maybe due to a little friction or too much grease on the ball? Anyway, I now have my truck home, the trailer is level and attached to shore power and the world is bright and sunny again (even though it's overcast and ready to snow here) !! This newbie wants to thank everyone for their suggestions and I look forward to meeting each of you at some rally eventually.
Carol
2004 Dodge Ram 2500 Cummins HD
1987 Excella 32'
"Besides, I'm a gypsy at heart
and I like to travel around."
Reba McEntire
LawChick is offline   Reply With Quote
Old 01-09-2011, 11:20 AM   #36
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Images: 55
Ray again - I suggested to my wife that our quote on the signature line might be better phrased as: "Not all those who are lost wander." LOL
Carol
1987 Excella 32'
Reba McEntire
Old 01-09-2011, 12:08 PM   #37
Splitrock's Avatar
Sioux Falls , South Dakota
On my Haulmark trailer, the hitch hangs up sometimes if I have back pressure on the ball. I might have to pull the truck ahead just a bit to get the ball away from the ball wedge that's located at the rear of the ball cup. I haven't looked at the Airstream hitch because I haven't had any problems unhitching it. With my utility trailers, it's not enough to lube the ball (which I do). I also lube the ball wedge and the release mechanism.
I use this on the ball.
I get it from Rockler.
I tend to like Marvel oil on the hitch ball wedge.
My remote location plan for the electric tongue jack / dead battery scenario, is to jack the tongue off with a bottle jack. I have the bottle jack in the tool kit. If I'm near my shop with a failed electric jack, I'd just jack it up with a floor jack. I'm not a real big fan of electric jacks. I might just replace my travel trailer electric jack with a hand crank jack. I have hand cranks on both of my other tandem trailers and I like their never fail reliability.
Gary
Old 01-09-2011, 12:39 PM   #38
_
Originally Posted by LawChick View Post
This is Ray, well - it came apart finally (actually rather easily too). The trick was to attach the shore power and use a concrete block to gain a little height...
good follow up ray
i'm no elec'pert but my understanding is...
the jack is powered by the trailer 12v system...
so the battery/ies was/were probably low.
typically there isn't enough juice via the 7 pin to power the jack fully OR recharge the batteries quickly.
this is why leaving it plugged in to shore power over night helps or using shore power real time helps.
if the charger/converter is working and the batteries healthy, getting them fully juiced may be the solution.
of course the wiring to the jack could be pinched/frayed and not suppling full power,
or the battery/s may be weak, dry, sulfated or otherwise inadequate.
hopefully u r correct it's just a juice issue or something very simple.
congrats and welcome to the lost, wandering and wondering masses.
cheers
2air'
Old 01-09-2011, 02:21 PM   #39
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Yea!
Things definitely work better when there is enough power. Glad you got everthing taken care of before the snow started. It's 3:20 now and it is building up here in SE Little Rock. It started here about an hour or so ago and is seriously coming down.
Vaughan
Old 01-09-2011, 02:41 PM   #40
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Glad you got it loose. Is your truck a 2W or 4W drive. We had to have about a 6" drop on our hitch for our Dodge 4w. I think if you get hitched level and get a new batteries for the camper it will work fine. The jack really has to have good power because you are lifting the truck also. Our truck only settles about 1/2 inch when we hitch. So to attach the bars, etc. we have to actually lift the suspension at the back of the truck also with the jack.
Old 01-09-2011, 03:37 PM   #41
JFScheck's Avatar
Rockville , Maryland
Images: 33
Hey Ray - congrats - now open up your own account here so we can properly "haze" you and welcome you into the community...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 01-10-2011, 09:31 PM   #42
REBurt's Avatar
1987 32' Excella
Ray here - I do have my own account as you can see - but sometimes it's easier to use Carol's when she's logged on and in the thread than to login and go to the thread to reply. I'm a little lazy sometimes and take the path of least work.
1987 32ft Excella
2004 Red Dodge RAM 2500HD Turbo Diesel
A bad day on the road is better than a good day on the job - but it's still bad !!!
REBurt is offline   Reply With Quote
