Old 04-26-2012, 07:09 PM   #29
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Billy,
Adding that set-up to the rear suspension will NOT transfer any weight to the steering axle. It will ONLY keep your rear-end from squatting.
A weight distributing hitch is the only way transfer the needed weight.
Roadmaster Active Suspension....you'll notice there is no mention of weight distribution on the site.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-26-2012, 07:52 PM   #30
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Thats what I thought, but I sat there as he scrolled around on his 'puter' and was telling me that this rig would justify all that. sooo. what do you think of the class V hitch?
I took the reese straight hitch off and put this new one on (to be tested near the end of the month.) I am hoping to meet up with Melody Ranch in W Falls Texas at the end of the month also. There- we will get a lot of advice from him, as I will be able to show him the reese up close so he can tel me what to do with it as far as lowering the level of the ball.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-26-2012, 08:03 PM   #31
1970 27' Overlander
Andy's email -FYI
Originally Posted by AndrewM View Post
Would anyone mind either posting Andy's email here or meesaging it to me? I have a similar question for him I would like get his input on.
Oh and I believe he is spot on in your case.
Let me look...the email is....andy@canamrv.ca
Old 04-26-2012, 08:14 PM   #32
Thumbs up
Billy,
If that's the proper drop to keep the trailer and truck level when hitched it should work fine.
Some folks like the "big buck" adjustable stinger, but if your not going to be changing TV any time soon the regular class V is good.
PFC
"Tahawus"
RLC
John Prine
Old 04-26-2012, 08:34 PM   #33
1970 27' Overlander
Thanks Bob for writing back and forth with me about this.
Being able to pull the Airstream with out being nervous or un sure is an on going check list of 'to-dos' -- sometimes it seems like it is never ending...need to get this, need to get that, on and on. ha. This coming weekend we are planning to pull it about thirteen miles north of here to the quartz mountains. Walnut--I mean Walmart is on the way and we plan to stop there to do some maneuvering ...and some more exercises.
The other thing I have also realized is I can't back the Airstream with out any success, but we have not practiced yet either. There has got to be a trick to it. I always thought you just kept your eye on the far rear of the AS and it would go where you steered (using your hand on the bottom of the steering wheel.) Well everyday is a chance to make everything better. Right now I am working on an old grandfathered sign over on Broadway (here's a picture of it getting prepped.)
Old 04-27-2012, 05:12 AM   #34
Thumbs up Backing up....
Billy,
Three tips....
Put one hand at 6 o'clock on the wheel. Move that hand in the direction you want the back of the trailer to go.
Always try to back up over your left shoulder, using your big mirror's, you lose perspective quickly using the right mirror.
Most importantly...all backing done SLOWLY, ignoring all onlookers.
Glad to see you haven't dropped the "brush"...
PFC
"Tahawus"
RLC
John Prine
Old 04-27-2012, 06:10 AM   #35
1970 27' Overlander
Robert I figure the man at the shop just wanted to make a sale real bad, and was doing his best to be 'slick'. ha
This Airstream, the tow truck and me and Angel with our spirits looking out of our heads - is what motivates everything. We look around at some of our friends and they are stuck in one place and have been for years and years. I knew this Airstream we have is the reason for living and to keep on living. That would have been kind of funny (but not) to see Thelma and Louise go over that cliff while pulling an airstream at the same time.
Sure thing I will practice the steering method, I actually am a very good driver with everything else.
I have already had the truck weighed by itself at our scales about two blocks away from here where we are at. So also on the list is to weigh in with everything hooked up.
So when I do this, and I am about to pull up on the scales, what is the procedure?
Old 04-27-2012, 06:33 AM   #36
Thumbs up
Billy,
This what I have done when setting up a new TV. Others may differ slightly...
Get the base weight of the TV loaded as it will be used towing. Full fuel gear etc.
Get a combined weight, TV & AS without WD set.
Get a combined weight with WD set, you may have to re-weigh several times to determine the best set-up.
Your goal is to return as much weight back to the TV steering axle as possible while keeping the entire rig LEVEL.
Pay attention to axle loading on the TV and trailer and adjust your tire pressures accordingly.
Here are three tickets from a "heavy" trip we took several years ago.
Notice that when we weighed the rig without WD a significant amount was taken off the steering axle. 760lbs.
After WD adjustment all but 100lbs was moved forward to the TV steering axle, with a portion going back the the AS axles.
Hope this helps...
ID:	156869   Click image for larger version
Name:	CAT Weights.jpeg
PFC
"Tahawus"
RLC
John Prine
