Old 06-27-2015, 10:52 AM   #1
2015 30' Flying Cloud
Westport , Connecticut
Broken cable for the brake/break away
Hi everyone:
23 days til take off from CT! Wow. Feels so exciting!
Our beauty, (R)o(V)er is getting all dolled up and ready to go.
Okay, she's not REALLY that precious, I just like words.
Here's a problem. The brake away (or is it break away??) cable BROKE! Yikes. Don't want to leave without fixing that important piece.
Advice greatly appreciated.
Best,
Kira
KiraR is offline   Reply With Quote
Old 06-27-2015, 11:13 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Easy fix. Get a piece of wire and replace it.
MICHAEL
Old 06-27-2015, 11:34 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Not only is it an easy fix as mentioned previously, it would also be illegal and potentially very dangerous to tow the trailer without this important safety feature working properly.
Bob Martel
WBCCI# 5766
Old 06-27-2015, 12:54 PM   #4
1974 Argosy 20
Kooskia , Idaho
Any decent RV parts place will have replacement cables for your break away switch, and if not, a new switch is still cheap and easy to install. There are several different ones used, if possible take your old one along to compare.
I do not recommend trying to repair the original cable.
Old 06-27-2015, 03:59 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Lowes & HD have the stuff also. They have a soft coupler that you can slip on and then with a cold chisel tap it shut to crimp to the cable. Cheap and easy.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-27-2015, 05:33 PM   #6
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
order a new cable from Amazon - http://www.amazon.com/Fastway-80-01-...reakaway+cable
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 06-27-2015, 06:04 PM   #7
Kevin245's Avatar
I'd just replace the entire switch. For what you'll spend in effort and money you'll end up saving money and know that your switch is functioning properly.
Eleanor Roosevelt
Old 06-28-2015, 11:58 AM   #8
greenflag's Avatar
2016 30' International
Quartz Hill , California
Get a Fastway cable mentioned in previous post. I replaced two previous cables before getting Fastway. Problem solved. I never drug another cable.
greenflag is offline   Reply With Quote
Old 06-28-2015, 12:17 PM   #9
Watertown , Massachusetts
on our last trip
On our last trip, we got home and realized that the cable had been dragging and worn completely through! After that we got one of the coiled ones and put it on, although we had to shorten it a bit. According to a recent article in the AS magazine, the stretched out cable is only supposed to be 5 or 6 inches longer than the chains.
The original one that came with the (new) trailer was much longer than that, and because it didn't coil up, it dragged easily. We had coiled it up a little bit ourselves and secured the coil with twisty ties, only to keep it from dragging, but apparently that didn't work.
sallye is offline   Reply With Quote
Old 06-28-2015, 01:22 PM   #10
Cousin Eddie's Avatar
2015 23' FB Flying Cloud
2003 25' Safari
Forestville , California
Buy and install a new switch. They generally cost less than $20. When mounting the new switch, do not tighten the lock nut completely. The switch must move freely from side to side. Any trailer repair place should have the part.
Bob, Julie & Punkin
Cousin Eddie is offline   Reply With Quote
Old 06-28-2015, 01:58 PM   #11
HowieE's Avatar
Princeton , New Jersey
Images: 12
You can make a new cable odds are if you buy one it will be the wrong length. but so far no one has given any information on how long it should be. If the cable was long enough to drag on the ground and ware through the original was installed wrong and far too long.
The cable should be of a length that it will pull the pin before the chains go tight if the hitch fails. That ensures that the trailer brakes are set as it brakes free of the TV. If not and you attempt to stop the TV the trailer will overtake you and it is bigger than your are.
I like to route the through a D clip in the top hole of the hitch drop bar. This ensures that it is at the pivot point and is kept away from anything it could snag on and prematurely pull the pin. I also route the umbilical cord through that D ring fr he same reason.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 06-28-2015, 02:18 PM   #12
AWCHIEF's Avatar
Images: 33
This is what my trailer has. The coiled cord works well to keep from dragging .
http://www.amazon.com/Fastway-80-01-...5522494&sr=1-1
MICHAEL
Old 06-28-2015, 02:24 PM   #13
HowieE's Avatar
Images: 12
I am sorry Mike rethink that. 4ft of cable with 2 ft. of chains. Think through a failure and what would have to happen to have that cable pull the pin.
2004 Excursion 4x4
Old 06-28-2015, 02:37 PM   #14
AWCHIEF's Avatar
Images: 33
It's all good. Nothing to lose any sleep about. At the most is it is closer to three ft and the switch sits at least 18 inches from the attachment under the bumper.
MICHAEL
Hook Emergency Break-away cable to what? OB Bambi Brakes & Brake Controllers 16 08-18-2011 03:35 PM
Break away brake cable Cap-N-Red On The Road... 26 04-10-2011 03:10 PM
Break away brake cable glogeo Hitches, Couplers & Balls 2 09-23-2010 03:57 PM
Break-away cable broke... crazylev On The Road... 9 08-16-2004 06:24 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 08:22 PM
