Old 10-20-2019, 10:48 AM   #1
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Broken 7-pin cover
Got a bit impatient with a stiff plug and yanked....broke the hinged flap that covers the circular opening. Definitely don't want to drive around getting grit/road-salt/etc. in there, but also sure as heck don't want to buy a hole new wiring setup...any know any smart fixes? Or even what its called (so that I can look up the price of that replacement part)
Thought about a rubber stopper tightly stuffed in there? Or even just getting one of those 7 pin to 4 pin adapters and using that as a 'plug'.
Couldn't see any kind of branding on the unit, so I'm guessing its a stock Toyota part.
ID:	354577   Click image for larger version
doughpat is offline   Reply With Quote
Old 10-20-2019, 11:04 AM   #2
rideair's Avatar
Buy them new all day long on eBay: search "Toyota 7-pin NOS". For $200.00-$250.00 can be your in just a few days, quick swap, ready to go. "OR" You can buy a standard Polk unit, spend hours figuring out the wiring, etc... I'd go "NOS" but then again, I like keeping things stock whenever possible.
https://www.ebay.com/itm/2005-2015-T...4AAMXQkN5RCIP5
Paul Waddell
rideair is offline   Reply With Quote
Old 10-20-2019, 11:11 AM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I obtained a replacement plug socket from an O'Reillys auto parts store. Pretty much plug-and-play for not much $. 2004 Silverado though.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 10-20-2019, 11:49 AM   #4
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
If you're looking for the *cheapest* solution, I think your idea of just using a 4 pin adapter is a good one.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 10-20-2019, 11:50 AM   #5
1972 25' Tradewind
Denver , Colorado
If you're looking for the *cheapest* solution, I think your idea of just using a 4 pin adapter is a good one. Make sure the adapter has a cap over the four pins though.
Old Yesterday, 01:28 AM   #6
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Out of curiosity...why would the cap matter? It’s sort of a “sacrificial” piece.
Old Yesterday, 06:33 AM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Take a look at the broken cap, does it have a tab or hook that locks the plug in place? That's a good thing, keeps plug from wiggling out.
If you look at Hopkins http://www.hopkinstowingsolutions.com/ you might find a replacement plug assy if your's has a snap on cable to receptacle assy.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old Yesterday, 08:36 AM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
Don't you kinda need the cover?.....Mine have a tab on them that hold the plug in the socket
CRH is offline   Reply With Quote
Old Yesterday, 09:03 AM   #9
2017 23' Flying Cloud
Bartlett , Tennessee
Looks like the wiring harness just plugs into the back of the outlet. Go to Toyota and buy a whole new 7 pin outlet. Unplug the wiring harness, remove the broken unit, install the new unit.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old Yesterday, 10:14 AM   #10
aftermath's Avatar
Spokane , Washington
I don't get the 4 pin quick and easy replacement idea. Wouldn't you be sacrificing your brake controller? Battery charge line?
aftermath is offline   Reply With Quote
Old Yesterday, 05:46 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
I believe the OP was just intending to use the 7 to 4 adapter as a way to fill the socket to protect it when not in use.
Old Yesterday, 09:52 PM   #12
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Correct-it’s just a cheap way to keep road grit from entering the 7pin socket.
Old Yesterday, 09:53 PM   #13
doughpat's Avatar
2019 22' Sport
Bend , Oregon
You might have missed the part about a tight budget
I think the 4 pin adaptor as a make-shift “cap” is going to work fine.
Old Yesterday, 09:57 PM   #14
dznf0g's Avatar
Oswego , Illinois
Or....go online to the boneyard network and see what a Toyota connector costs off a wreck.
-Rich-
7 pin to 4 pin - Jeep wrangler 42570 Our Community 6 09-08-2010 10:44 PM
9 pin to 7 pin conversion ck21084 Electrical - Systems, Generators, Batteries & Solar 4 06-10-2010 03:58 PM
6-pin connector to AS 7-pin eugnicfrlie Towing, Tow Vehicles & Hitches 6 04-15-2009 11:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 02:34 PM
