Old 07-16-2014, 07:49 AM   #1
did
did's Avatar
2014 27' Flying Cloud
Apple Valley , California
Breakaway switch question.
New to this whole towing thing. Did I mess up by storing my 2014 27FB with the breakaway pin out? I wasn't informed, by the dealer, if I should leave it in or not. Am I going to find my batteries dead and did I do any damage?
Thanks for any info, Dan
did is offline   Reply With Quote
Old 07-16-2014, 07:52 AM   #2
did
did's Avatar
Oops!
"breakaway" not brakaway........Really, I'm not really illiterate. I just play one in real life. D.
Old 07-16-2014, 08:00 AM   #3
dznf0g's Avatar
Oswego , Illinois
Batts will be dead. I've heard some say that the magnets can be damaged by this, but I struggle with that.
-Rich-
Old 07-16-2014, 08:28 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The brake away switch is an emergency switch that applies the brakes if the trailer become disconnected from the TV while on the road.
Yes your battery will be dead. Replace the pin before you install a new battery.
As for the magnets. They can be tested individually with an amp meter to see what draw they take.
I would suggest you ask what they will do before you go in as most dealers are thiefs and will milk a new comer to death.
2004 Excursion 4x4
Old 07-16-2014, 08:32 AM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've heard the same thing. I'm not sure if the magnets themselves or the actuator that energizes the magnets is the component potentially damaged. Supposedly excessive heat is generated when the brakes are energized by a long term disconnect of the break away pin.
I guess that once the batteries are recharged you could take the trailer out to a parking lot and try to energize the brakes from your brake control. That would tell you if they are working. Supposedly a properly set up controller will supply enough voltage at the manual max power application that will keep the trailer wheels just short of locking up.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-16-2014, 08:56 AM   #6
HowieE's Avatar
Images: 12
When the brake away switch is activated the only things in the circuit are the battery, wires, and magnets.
Each magnet will draw 3 1/2 amps and the resulting heat from a prolonged draw may cause the potting material in the magnets to melt and allow a short or open within the magnet. The possibility of a short or open is why I mentioned doing a test to see just what amperage each magnet draws now. A short or open will cause a damaged magnet to draw a current different from the expected 3 1/2 amps thus indicating a problem with that magnet.
Yes you could go out on the road but that would not give any indication of the condition of a given magnet. One may be bad and you would never know it.
2004 Excursion 4x4
Old 07-16-2014, 09:20 AM   #7
dznf0g's Avatar
Oswego , Illinois
Here's what I struggle with....and I'm not doubting the possibility of heat damage....I've just never had occasion to experience yes or no to heat damage. What I question is, since the magnets are subject to high heat from both electrical resistance as well as A LOT of mechanical heat together when going down a mountain, for example, I can't see the heat from electrical application alone melting the pot material.
Anybody here actually experienced heat failed magnets from extended breakaway application alone?
-Rich-
Old 07-16-2014, 09:40 AM   #8
1974 Argosy 20
Kooskia , Idaho
I was parked at a friends place for 4 days, plugged in so my batteries were not run down. Somehow the break away switch pin got pulled out and the magnets were energized for the entire 4 days.
No indication of any problem in the thousands of miles since.
Old 07-16-2014, 10:02 AM   #9
HowieE's Avatar
Images: 12
If you reread my comments above you will note the word "MAY" was used to describe a possible failure point. Not that that is a given. The simple test here is to test each magnet with an amp meter.
This is a complete system test. Testing the battery, battery connections, the wiring, and each individual magnet and should take less than 10 minutes.
2004 Excursion 4x4
Old 07-16-2014, 03:00 PM   #10
did
did's Avatar
Thanks so much for all of your input, guys and gals. I just talked to the service dept. where I purchased it and their response was "Oops, I guess the tech should have said something." Ya think?
Old 07-16-2014, 03:11 PM   #11
1977 Argosy 24
Milltown , Wisconsin
I would say you are in for a new set of batteries. After being completely discharged and left dead for a while the batteries will not hold a charge for long anymore.
ventport is offline   Reply With Quote
Old 07-17-2014, 01:42 PM   #12
1981 31' Excella II
New Market , Alabama
It is entirely possible to ruin a magnet by running full current through them for hours. Heat will build up. They things are not made to run 100% power indefinitely. This would be a thing called duty cycle. Real life is that they would be used intermittently and usually not at full power. They should be tested.
Perry
Breakaway switch question JeweloJalopy Brakes & Brake Controllers 2 03-07-2013 04:51 PM
Breakaway Switch Question HowieE Brakes & Brake Controllers 17 08-01-2010 09:48 AM
Would you/did you buy it? Breakaway switch joatmon Brakes & Brake Controllers 3 05-11-2005 11:57 AM
Testing breakaway switch Sneakinup Brakes & Brake Controllers 6 03-20-2004 10:45 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
