Old 09-18-2017, 06:41 AM   #71
Missouri Valley , Iowa
Rodster, I've had two brake control modules fail on my 2015 F150 SCrew. One while on the road and the other in my driveway. The local Ford dealer tells me the modules have been redesigned. I've got nearly 2,000 mi on the replacement with no troubles.
Dan
Farmer Dan is offline   Reply With Quote
Old 09-18-2017, 07:58 AM   #72
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
I hope so. It was one scary experience. First, the smoke started rising from the dash and I got a brake failure message. At first I thought it was the truck and I was freaked. I do not know if you have been to Helen, GA but the ride from the Airstream park to town is downhill mostly and curvy. The whole place is hilly and curvy. Then the brakes locked and abruptly stopped the truck in a bad place. I hope I got a redesigned one.
WBCCI 8653
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 09-18-2017, 09:20 AM   #73
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Rodster,
I think your recent controller failure is worse than not having the brakes work, something we had on our maiden voyage a long time ago. We were able to get truck and trailer pulled over to the side on that downhill. Front disc brakes were smoking like crazy, smoke pouring out from wheel wells. But we had some control and the truck was bigger than the trailer, thankfully.
Glad you made it through your controller failure okay and yeah, hope they got you a good one now. I'd wondered about having built-in brake controller (ours doesn't) but yours is the first I've heard to fail.
Good luck and thanks for sharing what happened.
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 09-19-2017, 06:12 AM   #74
2006 25' Safari
Images: 8
More info...
The Ford dealer checked my truck using a trailer of their own. It did the same thing- burned up a controller. Then, to double check, my father and I did a break away test with my trailer- all fine, no problems there. The break away did not activate during my drive and, during the test, did what it was supposed to do. That leaves the truck at fault with these two tests.
What we found out was that Ford has REDESIGNED the break controller 3X since 2015. The part # for the latest model is GL3Z2C006CB.
From this experience I can say that the trailer will stop the truck and safely. It is just that depending on the road type you are on, it can have a profound impact on your nervous system. Curved hilly roads heighten the experience!
WBCCI 8653
Old 09-19-2017, 07:24 AM   #75
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Ridsterinfl,
Good luck be careful and hopefully a successful outcome. SOON!
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 09-19-2017, 08:08 AM   #76
GCinSC2's Avatar
Breakaway Cable Length - What do you do?
Duplicated deleted
S/OS #001
Old 09-19-2017, 01:49 PM   #77
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
Rodsterinfl:
I'm very familiar with that stretch of road. I drive by the Top of GA airstream park on the way to work.
That must have been quite an adventure. Glad nobody was hurt. Than can easily happen there.
KK4YZ is offline   Reply With Quote
Old 09-21-2017, 01:38 PM   #78
2006 25' Safari
Images: 8
UPDATE
I have learned more on the Ford Brake controller on 2015 and newer F150s.
There are now seven different redesigns. The newest is not the one I was given and posted earlier. It is this one:
JL3Z19H332AA
this supersedes all previous six versions - FL3Z2C006AA, FL3Z2C006AB, FL3Z19H332AB, FL3Z19H332AA, GL322C006-CA, GL322C006-CB
WBCCI 8653
brakes, emergency, hitch, safety, brakeaway
7 wire cable length ? LI Pets Towing, Tow Vehicles & Hitches 6 03-07-2007 10:37 AM
Breakaway switch. FreshAir Brakes & Brake Controllers 44 02-12-2007 11:18 AM
Breakaway Switch PunkZTT Brakes & Brake Controllers 24 05-02-2006 11:48 PM
breakaway switch aeriqua Brakes & Brake Controllers 2 01-09-2006 06:48 AM
Trailer breakaway cable wayner1239 Brakes & Brake Controllers 47 12-08-2003 06:13 PM
