Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 02-09-2005, 08:44 AM   #1
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
Brakesmart & Hensley setup
What settings are you using with your Brakesmart and Hensley hitch?
Dwight is offline   Reply With Quote
Old 02-09-2005, 10:49 AM   #2
Dwight
Dwight's Avatar
Joshua , Texas
Some folks that I have spoke with are using the following setup with a 30' trailer:
Adjust The Brake Controllers Gain: 3
Set Initial Brake Constant: 51
Set Beeper Mode: OFF
Old 02-09-2005, 04:09 PM   #3
Porky Pig
Cartoon Character
Porky Pig's Avatar
Profile:  2004 34' Classic
On The Road , U.S.A.
Whatever the default settings were from the factory ... I started out with those ... everything works great ... so I left it that way.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 02-09-2005, 06:55 PM   #4
johnbaker
johnbaker's Avatar
Profile:  1978 Argosy 30
Dallas , Texas
Images: 11
Dwight,
I agree with Porky Pig. I have a 99 tri-axle and found the factory setting fine.
this past September, I had it converted to disc-brakes, factory setting too agressive so I dialed it down by 2 or 3. It works unbelieabley nice, there is so much braking power and they never fade!
John Baker
1978 Argosy 30
Hensley
Excursion
johnbaker is offline   Reply With Quote
Old 02-10-2005, 07:45 AM   #5
Jimmy311
Profile:
Disc Brakes
What type of disc brakes did you retrofit?
Jimmy311 is offline   Reply With Quote
Old 02-10-2005, 10:23 AM   #6
johnbaker
johnbaker's Avatar
Dallas , Texas
Images: 11
Since I live in Dallas, I took the A/S to BrakeSmart and had the disc conversion done there. Since they designed and make the brake controller, I just felt better about the disc conversion done there (price was comparable to other vendors). I can't remember the part's manufacturer but I know replacement parts are available at NAPA and other auto supply outlets that carry brake parts. If you want the specifics, I'll call BrakeSmart (its a local call).
John Baker
1978 Argosy 30
Hensley
Excursion
Old 02-10-2005, 02:00 PM   #7
Dwight
Dwight's Avatar
Joshua , Texas
John,
I would be interested in the cost for converting the brakes. I also have a 1999-34' and Hensley.
Old 02-15-2005, 07:00 AM   #8
Jimmy311
Profile:
Disc Brakes
John Baker or anyone else with input,
I have been looking into the conversion to disc brakes. Since you are in Texas, most likely you got Kodiak hub/rotor/caliper. The actuation is what I think is the biggest component to the conversion. If you know what type of actuator/hydraulic pump you have that would be great. Also while I am on it. Do you notice a slight delay from the time you start braking until the trailer brakes kick in?
Old 02-15-2005, 04:22 PM   #9
johnbaker
johnbaker's Avatar
Dallas , Texas
Images: 11
Jimmy,
Yes, Kodiak is the brand of the disc assemblies, the BrakeSmart customer service has closed for the day, I'll call them in the morning and get the electric Hydralic booster info. As far remember, delay was less than 1/10 a second, I'll verify tomorrow.
The BrakeSmart controller (get's hydralic pressure from tow-car) coupled with the elechydralic, had the fastest reaction time (when I was checking on the conversion).
Dwight,
The cost of the tri-axle conversion was $3300. I already had the BrakeSmart Controller. There are other controllers that are compatable but I don't know which ones are recommended.
John Baker
1978 Argosy 30
Hensley
Excursion
Old 02-26-2005, 11:41 AM   #10
Dwight
Dwight's Avatar
Joshua , Texas
I have tried many setup combinations and have found that the "BCG" (Brake Control Gain) works best set at 54 and the "IBC" (Initial Brake Constant) works best set at 50. I spoke with the Hensley folks when they sold the TruControl units and their units came with the "IBC" already set at 50.
What screen do you monitor on your Brakesmart? I use the "amps" and "voltage" page.
Hensley Arrow Hitch Les Hitches 10 02-28-2007 09:59 PM
Hensley, Pullrite, etc. markjoandall Hitches 20 10-27-2002 06:51 PM
Hitch Setup Jabba Hitches 2 10-04-2002 11:33 AM
Is a Hensley overkill for a 22' trailer? Charcigar On The Road... 11 08-07-2002 09:59 AM
Hensley Arrow hitch update-- greasing John Hitches 0 04-17-2002 10:28 AM
