Old 04-19-2009, 10:44 AM   #1
2007 28' International CCD
1999 34' Limited
2009 22' Interstate
Woodbury , Minnesota
Brake controller for disc brakes
I have a 2007 chev 2500 duramx with a built in brake controller. I am buying a 30' Classic Limited with disc brakes. Is it true that I have to buy a additional brake controller? If so, what should I buy.
dickschaak is offline   Reply With Quote
Old 04-19-2009, 11:22 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
yes, you will have to buy a separate controller. There is one model Tekonsha and one model Hayes controller that will work well with the disc brake actuator. I think they are the P3 and Genesys, respectively.
Old 04-19-2009, 11:41 AM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
The Prodigy works well with disc brakes. I had disc brakes put on my Safari and it worked perfectly from the first test drive.
Al - K4GLU is offline   Reply With Quote
Old 04-19-2009, 01:44 PM   #4
1999 34' Limited
2009 22' Interstate
I have been told that my brake controller on my 2007 chev 2500HD pick up will not work on the 30 AS we are buying with disc brakes. If that is true what should I buy. Also, I have a Hensley hitch. The measurement fromthe pavement to the to inside of the receiver is 19.75. The measurement from the pavement to the top inside of the hitch is 18.75. What drop down do I need for the Hensley bar hitch?
Old 04-19-2009, 05:27 PM   #5
1960 24' Tradewind
Riverside , California
Hayes also makes a new G-2 model that will work with any Electric/Hydraulic unit. Active Technology has closed shop and the Actibrake unit will be/is no longer available, the Carlisle Hydrastar seems to be the best replacement andwillwork with any brake controller. Accproding to the Carlisle literature it say that both GM and Ford state in their literature that the in cab controllers should only be used with electric brakes (magnet). Hook up on the Carlisle is only 4 wires like a standard brake control.
ZoomZoom is offline   Reply With Quote
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Disc Brake Controller rrpranch Brakes & Brake Controllers 20 05-09-2007 11:25 PM
Disc Brakes on some '06 Raptorrider2001 2006 Safari SE 0 09-06-2005 07:09 PM
Disc brakes. Inland RV Center, In Brakes & Brake Controllers 23 06-28-2005 06:37 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
