Old 10-21-2010, 01:51 PM   #1
1988 34' Excella
Orlando , Florida
Bracket?
Can anyone please tell me the use of this bracket? It was installed by one of the PO's. A similar bracket is located on the other side of the frame in the same location.
Mike Eagle is offline   Reply With Quote
Old 10-21-2010, 01:56 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Since it's on both sides, it's probably part of a previous sway bar/weight distribution hitch set up...
TB & Greg and Abbey Schnauzer
#3954
Old 10-21-2010, 02:09 PM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Isn't that the muffler hanger bracket for an exhaust extension from the tow vehicle?
mojo is online now   Reply With Quote
Old 10-21-2010, 02:16 PM   #4
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Hangers for a WD hitch...
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 10-21-2010, 03:41 PM   #5
Those brackets are (were) for the Reese "dual cam" torsion sway control.
If you wish, saddles on the end of the arms that connected to those brackets, supported the cams that were on the end of the torsion bars.
As your rig turned, the cams moved over the saddles, one forward and the other rearward, which then "unequally" increased the torsion on the bars.
Old 10-21-2010, 07:06 PM   #6
1988 34' Excella
Orlando , Florida
Thanks everyone. I thought it might be some type of weight distribution system but I have never seen this design. I am removing everything that does not have a useful purpose so these brackets are history. They are being replaced by a new Reese strait line system per your recomendation Andy. Thanks again.
Old 10-21-2010, 07:35 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Maybe a support for a thermosan which transports the black water to the exhaust manifold. No kidding, there was such a gizmo in the early 70s.
All seriousness aside, I believe Andy is right for the umpteenth time
Old 10-21-2010, 07:39 PM   #8
Don't throw those brackets or U-bolts away.
You may need some of those parts with the new Reese dual cam sway control, especially the U-bolts.
Adding a third U-bolt to the new brackets, will keep them from sliding out of adjustment.
Fan Bracket Fishbone Roof Vents, Skylights & Fans 3 05-23-2010 10:42 PM
Awning Bracket 64TrotterAtl Awnings 1 09-25-2008 07:47 PM
Recognize this bracket? Jephellis Hitches, Couplers & Balls 2 07-12-2008 07:59 PM
What is this 'Bracket' for? FreshAir Repairing/Replacing Floor &/or Frame 16 10-15-2007 10:23 AM
awning bracket manley Awnings 2 08-22-2002 06:16 PM
