Old 06-09-2016, 02:27 PM   #15
HD Pilot's Avatar
2017 23' International
Decatur , Texas
Originally Posted by franklyfrank View Post
I learned to ignore the 1" above the trailer hitch height references. What is more important is how much your suspension settles from the weight of the trailer tongue on it. Mine settles over 2 inches and the WD engaged will only pick up about 1 inch. So I set the ball height accordingly and this of course varies from TV to TV.
I kinda hate to ignore an Instruction by the manufaturer but can see that for a heavier hitch weight like yours that may work. The hitch weight on a 23'FB is pretty darn light - 467 lbs as listed by Airstream so I do not think it will make my F150 squat very much.
I called the Hitch Source today and feel like I got some pretty honest help. The guy could not recommend the Blue Ox on the Airstream because of road clearance issues. I was worried about this too after hearing multiple stories of grinding/damaged U-bolts so now I am rethinking the Blue Ox selection.
This choice has been a complete PITA: Blue Ox - clearance issues, Equalizer - noisy metal on metal, HAHA/ProPride - super expensive, Anderson - tons of Threads/Posts on so many plus/minuses that it would take days to decypher, etc, etc.
Oh Well, I will figure something out. Thanks for the responses!
HD Pilot is offline   Reply With Quote
Old 06-09-2016, 06:47 PM   #16
1975 31' Sovereign
Valparaiso , Indiana
I am having the same height problems with the blue ox hitch and my GMC Sierra 2500. I have a six hole hitch and cannot get it low enough to level the trailer. How would I determine if I need a seven hole or nine hole hitch?
boilermaker is offline   Reply With Quote
Old 06-09-2016, 08:32 PM   #17
HD Pilot's Avatar
Decatur , Texas
I would do the same calculations I did to discover the problem with the 7 hole. If you look at the Blue Ox Installation Instructoins you will see info on all the different size hitches and by knowing you need to be 1" above the coupler height and measuring the height above ground to your receiver - you should be able to determine the best receiver to get. I would always opt for the smallest one that will meet the 1" above the coupler height requirement - it will be lighter and less likely to hit something.
Old 06-09-2016, 11:59 PM   #18
2015 25' FB Flying Cloud
Redmond , Washington
On our 2010 f150 the lower part of the receiver is at 17 inches... the truck is a 4x4 Lariat with the max tow package.
Having used no other wd hitch, I can't tell you much about other products out there, but I can say we are happy with the Blue Ox thus far. We tow a FC25 and the only time we had a clearance issue was getting on to a ferry ramp. Nothing major, the ferry, truck and trailer were all okay.
All the best!
wanderingduo is offline   Reply With Quote
Old 06-10-2016, 09:49 AM   #19
Anna Maria , Florida
What ? Road clearance issues with the BO, you have to be kidding me !
When the trailer is leveled its leveled. Regardless of what hitch one uses. You would only need to use the 9 hole receiver to get low enough for an Airstream would be on a F-250 which sits higher to begin with.
franklyfrank is offline   Reply With Quote
Old 06-10-2016, 11:06 AM   #20
HD Pilot's Avatar
Decatur , Texas
Different hitch set ups will be closer to the ground than others, not an expert on all ot the hitches ground clearances but have read/heard of the Blue Ox dragging from multiple sources now. Yes, the TT should be level but still the Blue Ox appears to have more scrapping than others...I have not ruled the Blue Ox out, it is just another consideration that I take into account. Sounds like you have not had a problem, that is positive feedback in my decision making.
I just happen to have a 1997 F-250 4x2 and the trailer receiver sits 3" lower than my 2015 F-150 4x4, so there is a lot more that goes into receiver height than whether it is a 150 or 250. I'm sure I could get away with the 7 hole on my F-250 but don't think so on my F-150.
Old 06-11-2016, 02:02 AM   #21
True. However, to achieve this level some component of a hitch ends up lower than the tongue height of the trailer and that lowest part defines your clearance. HD Pilot seems to be trying to ask around to see which hitch has suitable clearance. A smart exercise before buying one, I am sure you'd agree.
I just saw another post on this forum about someone having to change out their 'u' hooks on their wd bars because they were bent, apparently from dragging....
http://www.airforums.com/forums/f464...ox-149678.html
I would encourage you to continue to do your research, HD Pilot! And then please share your findings here so the next person has a better starting point to decide which hitch to get.
Old 06-11-2016, 02:22 AM   #22
1991 25' Excella
Stanfield , Oregon
A friend of mine had her hitch setup at a Airstream dealer and she has to be very careful or her hitch well drag. The setup works well and tows good but has nil for clearance.
SpletKay06 is offline   Reply With Quote
Old 06-11-2016, 08:51 AM   #23
2014 19' International
Port Townsend , Washington
Just curious or point of clarification: when talking about the "hitch dragging" is that the entire Blue Ox (including the spring bars) or just the receiver?
When we first got our AS (19' Bambi) the very experienced dealer installed the BO on our Highlander and the spring bats would often drag a bit when going over curbs, i.e. service stations, parking lots, and as wanderingduo said ferry ramps!
Now with our F-150 it is fine - no problems. Again, that is with a 4x4 Lariat with a full tow package and a 6 hole Blue Ox. I did need to flip the receiver to level things out and reposition the ball. Part of the solution ion may have been my ability to now put more tension on the bars by taking in one more link on the chains. But real pleased with the BO.
LBelle is offline   Reply With Quote
Old 06-11-2016, 01:21 PM   #24
I had set up 3 different hitches over the last 3 years and do get anal about it myself. Setting up my F-150 with the BO I had to go to a 7 hole receiver and set the hitch ball at the lowest holes to get my ball height to 21" where I need it with my truck suspension set up. That is where I needed it with the Anderson and the Equalizer prior to that, to get the trailer level. My 30' International is level all around at exactly 17" bottom of frame to the ground. The Ball mount is about the same height for all these hitches and all three gave me identical ground clearance.
Old 07-16-2016, 08:59 PM   #25
HD Pilot's Avatar
Decatur , Texas
Just an update on my decision: I just ordered the Blue Ox with the 550lb bars. I know some people will say that I should have got the 750lb bars but the more I thought about the weights involved, I felt that the 550lb bars fit the best. The listed tongue weight for the 23FB is 467lb with full LP tanks so I have about 83 more lbs to spare on the tongue and we will be careful to not load up the front area of the trailer. We do not plan on going on long trips anyway so we will be traveling fairly light.
I also think the added benifit of lighter 550lb bars is that I will have to bend them a bit more than the 750lb bars which should give me more ground clearance. I also plan to grind down the ends of the U bolts in a rounded fashion close to the locking nuts - this should help with clearance and possible U bolt damage.
I thought long and hard over the Anderson and Equal-i-zer hitches but for many reasons I just could not go that direction. Hopefully the Blue Ox will work fine, even if I have to buy bigger bars later on - I can, more than what I can say about the Equal-i-zer hitch....
Old 07-17-2016, 09:32 AM   #26
You made an excellent choice. A slightly lighter bar will give you the same WD but a softer ride. I actually have a 1000# set and a 750# depending on how I am loaded.
I actually started with the Equalizer and used for over a year. The trunion bar set up works great as far as WD and sway control however it beats the crap out of you trailer especially if you also have the GYM tires. I had rivets pop and my shower door fell apart .
Following that I switched to the Anderson which was a total disaster. I followed through with their installation instructions including swapping out the coupler. It gave a fair WD performance after much experimenting with chain lengths and such but it had absolutely no sway control. The basic design is flawed. After a harrowing white knuckled ride with stiff cross winds out west last year I couldn't get rid of it fast enough. Reinstalled the original coupler and bought the BO and haven't looked back. The Blue Ox works great. And I am speaking from some hard earned experience.
Old 07-17-2016, 09:36 AM   #27
PS: Anyone interested in an Equalizer hitch with 1000# or and Anderson hitch contact me and you can have them for the price shipping to you from the Chicago area.
Old 07-17-2016, 10:22 AM   #28
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
-- snip -- give you the same WD but a softer ride. The Blue Ox works great. And I am speaking from some hard earned experience.
Thanks for sharing your experience. The point you make about the same WD is a point of interest as well. It parallels the experience of the Reese users, but it is not logical to me that a set of bars, which are lighter than the load, will transfer enough weight. Can you expand on your thoughts?
Travel safe. Pat
"How tight is the WDH?" FreshAir Hitches, Couplers & Balls 3 04-29-2008 05:36 PM
WDH spring bar Grease Caps FreshAir Hitches, Couplers & Balls 7 02-19-2008 04:54 PM
Reese Dual-cam WDH vs. Equal-i-zer Hitch AndyPenny Hitches, Couplers & Balls 20 02-18-2008 12:22 PM
Hitch Spring Weight on WDH (Reese vs. Equal-i-zer) AndyPenny Hitches, Couplers & Balls 4 11-09-2007 06:05 PM
Newbie WDH question/advice myoung Hitches, Couplers & Balls 41 01-09-2006 11:12 AM
