Old 06-23-2015, 01:02 PM   #57
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I have a Blue Ox Sway Pro. It is the only WD hitch I have tried so far. When set up correctly it seems to work fairly decent. I am towing a 31' footer with a 1/2 ton truck and I get some sway from time to time. I have learned that keeping my fresh water tank at least half full levels out the load better and eliminates more sway than the hitch ever did though. If the opportunity ever arises I want to try a Hensley or ProPride and see if they really will eliminate all the trailer sway.
Echelon73 is offline   Reply With Quote
Old 06-23-2015, 03:43 PM   #58
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
From above, "If the opportunity ever arises I want to try a Hensley or ProPride and see if they really will eliminate all the trailer sway."
They will, as well as the push out of alignment you feel when a semi passes you. The difference was very apparent a few miles into our first trip with one, will put a smile on your face.
Doug and Cheryl
Old 06-24-2015, 12:24 AM   #59
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by JGB View Post
I went to the Blue Ox based on the dealer recommendation when I traded up from a 23 Int. to a 26 Int. Was previously using an older round bar hitch. I used the Blue Ox for about 500 miles and was unsatisfied with the set up. The hitch head angle on a Blue ox is not adjustable, so the only options for set up are ball height and bar tension. IMO having an adjustable hitch head angle is essential in getting the trailer level and the weight distribution dialed in for the requirements of the tow vehicle.
"My towing experience with the Blue Ox was OK, but not right on. "
I believe dealers are pushing Blue Ox because they are a quick no brainer to install, and they on average work pretty well. I cannot comment on Pro-Pride, as I have never used one, but Blue Ox did not have enough adjustability for my specific application, or liking. I tow with a 3/4 ton diesel P/U
Guess I am wondering what "OK" is...The newer BlueOx was designed so you don't need to fool with the "angle". I certainly can own which ever hitch works best and is safe. After 4 hitches, and 2 BlueOx on last couple AS's, when set up with proper size bars, no issues with BO... On the other hand, there are arguments from some because they like to tinker...to each his own...
Old 06-24-2015, 07:06 AM   #60
K.C. , Missouri
And further thought regarding that earlier post about the blue ox, I respectfully suspect the setup was not done correctly. It was stated that "the head angle needs to be adjustable to get the trailer level". My understanding and experience setting this up was that the getting the height of the ball correct is what determines making the trailer level.
The head angle is to in effect give a starting preload for the bars to be able to transfer load from the drive axle to the steer axle ( and back to the trailer axle(s).
gmw photos is offline   Reply With Quote
Old 06-24-2015, 08:45 AM   #61
dkottum's Avatar
Hitch head angled down towards the rear helps with the stability of the tow vehicle in turns and resists the movement of the trailer off center alignment going down the roadway.
Andrew Thomson (Can-Am Airstream) wrote a good article about it a few years ago. Anyone have the link?
Doug and Cheryl
Old 06-24-2015, 08:48 AM   #62
Echelon73's Avatar
I hate to start a new thread to ask this question, so I will just ask it here. How much do you feel a used ProPride is worth (3-4 years old)? I am really wanting to try one, but I just wonder how much should I be willing to pay for a used hitch. Any ideas?
Old 06-24-2015, 08:53 AM   #63
dkottum's Avatar
Echelon, call ProPride and ask if they have any reconditioned ProPrides available.
Doug and Cheryl
Old 06-24-2015, 09:03 AM   #64
Echelon73's Avatar
I have a lead on a 3-4 year old one that has the WD bars correctly sized for about $1500. Do you think I am better off going for this deal (local) or calling Sean about a reconditioned one? I guess I could just call him and see what he has available.
Old 06-24-2015, 09:27 AM   #65
67 Globetrotter
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
Thanks everyone, helped me alot. Bought with confidence!
I bought a Blue Ox today off ebay, reconditioned from a dealer with alot of good feedback on product. Apparently these are from customers that don't buy the right equipment so change orders.
We'll see. I drove my AS home 3 hours without any issues. I had to even watch my speed once I got comfortable on the highways. She rode so well I caught myself a few times forgetting she was behind me going 70. LOL
I did get slight sway when some rigs passed, but nothing white knuckle. I'm mostly concerned about overall safety especially if I travel on the plaines in high winds and such...
I spent 225.00 on Blue Ox. I'm one of those weekender, local gals for the most part. Hard to justify 2K at this time.
Just to clarify: I got the 550 lb tongue weight. I'm towing a 67 GT with a Saab 9-7x V8. Pretty light weight and from what I've read too stiff can damage things. My GT specs are: 3010 weight, 396 Hitch Weight.
Airstream moved the specs link so I thought I'd put it here.
Document Archive - Airstream
Thank you everyone!!!!
KrisE MN is offline   Reply With Quote
Old 06-24-2015, 09:41 AM   #66
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
On the Blue Ox website, they have different length shank balls to help get the ball to the correct elevation since the hitch head has only 1.5" increments for elevation changes.
Old 06-24-2015, 09:54 AM   #67
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Just wondering if the standard shank for the Blue OX is good for a 1/2 ton pick height. Can't recall the distance from the ground to my Tundra's receiver.
Kelvin
Old 06-24-2015, 10:47 AM   #68
67 Globetrotter
KrisE MN's Avatar
Video on Installation
I don't know if that's correct. From this video at least... I guess I'll find out and let you know. This video helped me alot! E-trailer video:
http://images.etrailer.com/Merchant2...n-bxw1000.webm
Old 06-24-2015, 03:48 PM   #69
K.C. , Missouri
Well yes, and what Doug says here is true too. The fact the head angles down, and that the trunnion pivots ( on a BlueOx anyway ) angle slightly outward at the bottom when viewed from the rear, create a geometry that effectively makes the bars want to self center. Hence: "antisway".
It works, or least I can say it works with my rig ( Nissan Frontier with 19' SOB ) and I could tell a very noticeable difference between just "on the ball" vs "with the BlueOx", especially on very windy days where the wind is gusting from the side. Just on the ball, a heavy side wind, I could tell it was moving around back there. Not dangerous like, but for sure, I knew it was there and moving side to side in the gusts. With the blue ox, I really almost have to be trying to see if it's actually moving around. In all honesty, the truck all by itself with nothing in tow does "some moving around" in side wind gusts, so I reckon I can't expect it to be totally perfect when hitched. Hey, it blows a LOT here in the midwest.
Old 06-25-2015, 10:09 AM   #70
KJRitchie's Avatar
2008 25' Classic
I contacted Blue Ox asking them what size bars; 1000lb vs 1500lbs given my hitch weight of my AS is between 1100 and 1200 lbs. They recommended the 1500lb bars.
I use the 1000lb bars on my Equalizer. Given the Blue Ox bars are tapered vs the Equalize bars which are square throughout the whole length is the 1500lb Blue Ox bars the correct choice?
Kelvin
2004 Blue Airstream Land Yacht 30ft Class A Motorhome, Low Mileage! S2004 Blue Airstr eBay Watch Airstreams on eBay 0 03-23-2012 12:40 AM
Propride hits the market TROPHYJIM2 Hitches, Couplers & Balls 59 04-01-2009 08:07 PM
Why do you have the Blue Beret? What is the Blue Beret for? PeeWee WBCCI Forum 12 02-22-2009 11:55 AM
