Old 11-23-2014, 01:29 PM   #43
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
We have owned a Reese, a Hensley, and 2 Blue-Ox over the past 8 years with 3 AS's. The Reese broke and ended up with our first Blue-Ox few years back as it was all they had in stock. . It worked well for us over 2 years we owned our rig- back/forth TX-MT... when we got our new FC in June this year, we could have purchased any of the featured hitches, but chose the Blue-Ox. Once you learn the trick with power jack in front, hitching/un-hitching is not an issue, and it tracks true with all the "road" hazards mentioned in this thread. For us, Blue-Ox works great. Would purchase again.
Old 01-31-2015, 02:49 PM   #44
2013 30' International
Kennewick , Washington
I am buying a 2013 30 foot signature and pulling it with a 2013 gmc 2500 diesel. Wanting to buy the blue ox hitch but the truck hitch sits 21.5 inches off ground and the trailer sits 19.5 inches. The blue ox hitch is a zero drop hitch, what is the best way to make up the difference
Garmat is offline   Reply With Quote
Old 01-31-2015, 03:01 PM   #45
r carl's Avatar
Lin , Ne
Put 1000k in the bed.
Old 01-31-2015, 03:10 PM   #46
Tincampers's Avatar
Sneedville , Tennessee
The Blue OX comes with an adjustable stinger having up to 9 holes spaced about 1.5" apart. You should be able to match up just about anything. My Suburban is about 2.5" higher than the trailer and I have no problems at all hooking up nice and level across the trailer and truck.
Tincampers is offline   Reply With Quote
Old 01-31-2015, 03:29 PM   #47
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I did have to go with a longer than supplied stringer for my Jeep. Blue Ox sent me a replacement at no charge. Outstanding customer service from them.
MICHAEL
Old 02-01-2015, 08:02 AM   #48
Will the 15,000/1,500 tongue weight be too large of a equalizing hitch for a 30 foot international. I want to buy the blue ox system. The other option is the 10,000/1,000 size.
Old 02-01-2015, 08:11 AM   #49
AWCHIEF's Avatar
Images: 33
Garmat, recommend you call Blue Ox and discuss this with them. They will be able recommend the proper bars for your specific application. They have some very helpful and knowledgeable people there.
MICHAEL
Old 06-22-2015, 04:46 PM   #50
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
What weight bars are being used on the Blue Ox Pro for AS 25? I'm thinking of switching from my Equalizer. My hitch weight is close to 1200lbs.
Kelvin
Old 06-23-2015, 07:24 AM   #51
gypsydad's Avatar
Kelvin
We use 1000 # but I would call them and inquire to be sure. They are very helpful. This site has the bars listed and phone number at the top.
Blue Ox Sway Pro Spring Bars
Old 06-23-2015, 07:28 AM   #52
Plasma800's Avatar
houston , Texas
I did the blue ox... that propride looks like there's a gazillion steps.
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 06-23-2015, 07:29 AM   #53
Plasma800's Avatar
houston , Texas
buy the longer shank. I had to go to a 9pin shank. Also, you probably have a 2 1/2 receiver, so buy the appropriate shank.
'15 27fb Signature
Old 06-23-2015, 08:57 AM   #54
JGB
Seattle , Washington
I went to the Blue Ox based on the dealer recommendation when I traded up from a 23 Int. to a 26 Int. Was previously using an older round bar hitch. I used the Blue Ox for about 500 miles and was unsatisfied with the set up. The hitch head angle on a Blue ox is not adjustable, so the only options for set up are ball height and bar tension. IMO having an adjustable hitch head angle is essential in getting the trailer level and the weight distribution dialed in for the requirements of the tow vehicle.
My towing experience with the Blue Ox was OK, but not right on. I believe dealers are pushing Blue Ox because they are a quick no brainer to install, and they on average work pretty well. I cannot comment on Pro-Pride, as I have never used one, but Blue Ox did not have enough adjustability for my specific application, or liking. I tow with a 3/4 ton diesel P/U
JGB is offline   Reply With Quote
Old 06-23-2015, 09:55 AM   #55
KJRitchie's Avatar
2008 25' Classic
Does the Blue Ox work as well as the Equalizer? I have an Equalizer and after a couple of years with it I don't like it much anymore. Trying to adjust it with spacers and having to torque down the hitch head bolts to almost 400lbs after adding/removing spacers is a chore. After a week on the road it started to grind and groan and then you have to relube the head. The WD bars fit in the sockets sloppy and starts to bend the retaining clip pins. I looked at the Blue Ox Pro and it seems simpler to install, maintain, and adjust.
Looked at a Hensley hitch on an Airstream last week and it looks massive which gives me an idea of what a Propride would look like. No doubt they are great WDH but I'm worried about the extra weight on my Tundra.
Kelvin
Old 06-23-2015, 11:50 AM   #56
gpt
sequim , Washington
i am using the Blue Ox but needed a longer shank because of the height of the F350 hitch. no issues with this hitch. easy enough to adjust the number of links so you are neither too tight or too loose. easy hookup makes it a pleasure to begin or end a trip. so far, no sway has been noticed at highway speeds or along the narrow 2 lane roads we frequently travel.
gpt is offline   Reply With Quote
2004 Blue Airstream Land Yacht 30ft Class A Motorhome, Low Mileage! S2004 Blue Airstr eBay Watch Airstreams on eBay 0 03-22-2012 11:40 PM
Propride hits the market TROPHYJIM2 Hitches, Couplers & Balls 59 04-01-2009 07:07 PM
Why do you have the Blue Beret? What is the Blue Beret for? PeeWee WBCCI Forum 12 02-22-2009 10:55 AM
