Old 11-19-2014, 11:04 PM   #29
2007 22' International CCD
True, in any case, the choice should be conventional or either Hensley design--that be the bottom line. They both work.
Tom T, you're probably just up the road from us. Used to drive past Orange on the way to work in Huntington Beach. I keep the AS in Victorville most of the time...storage issue in Corona.
KE4GNK/AE
Old 11-20-2014, 08:46 AM   #30
2016 30' Classic
Erie , Colorado
Along these lines I saw a post of a solo AS traveler, driving a Suburban/Yukon with a ProPride where the truck side factory receiver fell off. They were sitting on a hill and the trailer fully hitched with receiver attached rolled through the park, down the road and only a poor solitary tree stopped it from going over a cliff. Both wheels were in the air. Instagram Check out the rest of the Instagram thread and you can see the photos of the receiver and the lack of support from GM
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 11-20-2014, 08:54 AM   #31
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yikes! Some very lucky folks.
MICHAEL
Old 11-20-2014, 09:30 AM   #32
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have a Hensley with an adjustable stinger. For a fact it is heavier than the standard Hensley stinger. But it can be used on different tow vehicles (used to tow with two different height vehicles). The more important benefit from the adjustable stinger is that the tilt of the drawbar can be changed.
My 3/4 ton truck came with a pretty good rake from the factory. Hooking up the Hensley would have been much tougher with the drawbar pointing upward. Once I adjusted the tilt to be level with the ground hooking up is much easier.
As of yet I have not had loose bolts or cracked welds with the adjustable stinger.
I would not have trouble using a Hensley stinger but I would order it in separate pieces so I could weld it together myself with the proper tilt.
I once emailed Hensley about the adjustable stinger and got the same BS answer as above. Hensley has made this issue red herring.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-20-2014, 11:02 AM   #33
Tincampers's Avatar
Sneedville , Tennessee
Suburban/Yukon factory hitches are known problems.
Tincampers is offline   Reply With Quote
Old 11-20-2014, 09:11 PM   #34
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My neighbor's brother was here and when he hitched, the whole receiver moved about 20 degrees of rotation..
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-21-2014, 12:40 AM   #35
2015 25' FB Flying Cloud
Eugene , Oregon
You are all so amazing and so helpful...can't wait to meet some of you when I am on the road with my new AS!
atheness is offline   Reply With Quote
Old 11-22-2014, 03:49 PM   #36
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Thanks for everyone's comments and advice. I am really leaning towards the PP. However, I am still a bit concerned its the right hitch for my current TV (a 2014 Yukon Denali - short wheelbase) based on comments about know problems with the Yukon/Suburban receiver.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 11-22-2014, 04:36 PM   #37
I suspect that some reinforcement will be necessary no matter what the hitch...
But it is true the Hensley/ProPride hitch setups do put more force on the receiver because they do prevent sway. Those forces have to be absorbed or transferred from the hitch to somewhere else, probably the receiver.
Just the length of the stinger is more leverage...
KE4GNK/AE
Old 11-22-2014, 06:06 PM   #38
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The problems are from years ago. Check with Andy Thomson at Can Am
Old 11-22-2014, 06:37 PM   #39
mefly2's Avatar
2015 25' FB Eddie Bauer
Apples or oranges ???
Old 11-22-2014, 07:27 PM   #40
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
More like apples or lemons. The ProPride is much sweeter in my experience.
Doug and Cheryl
Old 11-22-2014, 08:59 PM   #41
Montgomery , Texas
So, the Denali receiver is no longer a problem?
Old 11-23-2014, 12:57 PM   #42
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The Denali receiver was upgraded, I think.. it was once a 'round' tube.. and fairly thin walled. The replacement is made of square tubing.. and more substantial 'wall thickness'..
The offer still stands for a 'test tow'...
Channing
WBCCI# 30676
2004 Blue Airstream Land Yacht 30ft Class A Motorhome, Low Mileage! S2004 Blue Airstr eBay Watch Airstreams on eBay 0 03-22-2012 11:40 PM
Propride hits the market TROPHYJIM2 Hitches, Couplers & Balls 59 04-01-2009 07:07 PM
Why do you have the Blue Beret? What is the Blue Beret for? PeeWee WBCCI Forum 12 02-22-2009 10:55 AM
