Old 04-22-2016, 09:00 AM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Blue Ox
Heads up for Blue Ox users.
Recently returned from a 2500 mile journey. Got home and discovered the U-bolts on the bars both deformed. As a preventative measure I went ahead and changed the U-bolts out. No way of nowing the cause but I did spend a lot of miles on rough Florida roads under going their continuing reconstruction. Better safe than sorry.
MICHAEL
Old 04-22-2016, 09:57 AM   #2
AWCHIEF's Avatar
Images: 33
Suppose I should add, nothing dramatic or life threatening involved. Anything man made has a tendency to failure sometime in its life span.
MICHAEL
Old 04-22-2016, 10:05 AM   #3
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I have same problem with one side U-bolt a little bent. When pulling out of space or driving over a speed bump, if there is a "dip" in the ground, or a "bump", one side (or both sides) can catch on the low point on the bars. I am now always "very careful" when in this type situation. Don't think the equalizer has this issue, but could be wrong. My F150 hookup sits pretty low the way it is set up level when loaded with AS.
Old 04-22-2016, 10:19 AM   #4
AWCHIEF's Avatar
Images: 33
That could be what caused the deformed U-bolts. I did bottom out a couple of times on the trip both front and rear of the trailer. When I put on the new bolts I trimmed the excess length flush to the lock nuts.
MICHAEL
Old 04-22-2016, 10:41 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Don't forget Blue Ox says to put red threadlocker on all threads. Those U-bolts are not something I would want coming loose and falling off while towing.
Old 04-22-2016, 02:09 PM   #6
K.C. , Missouri
picture ?
Chief, could you post of a picture of the damaged u-bolt ? I'm having a hard time visualizing this. I have close to 30K miles towing with mine, and the u-bolts are only showing signs of wear at the point they hang from the chain.
my badge of honor here:
"a genius nanny boy that drools in public"
....this according to a "slow-moving" poster here on the forum.... ( thanks )
gmw photos is offline   Reply With Quote
Old 04-22-2016, 02:50 PM   #7
AWCHIEF's Avatar
Images: 33
Sorry, already tossed them. Really nothing impressive to take pictures of. Just bent, one slightly to the side and the other towards the rear of the bar. I probably could of gone years and never had a real issue. As I said it was preventative maintenance. Just something to keep an eye on.
MICHAEL
Old 04-22-2016, 08:55 PM   #8
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
AW - were the threaded ends below bar bent or was the U-section above bar bent? Did the replacements come from Blue Ox or a hardware source? Any specific specification?
Thanks for posting the information. We all benefit from the sharing of our experience.
Pat
Old 04-22-2016, 09:32 PM   #9
AWCHIEF's Avatar
Images: 33
Pat
Bent both top and bottom.
Replacements were Marine Stainless from Lowe's. Took the old one in and matched it as close as possible.
Used the stainless because they had no galvanized U-bolts anywhere close. Theoretically should be stronger than the originals. Will of course keep a close eye on them.
MICHAEL
Old 04-22-2016, 10:39 PM   #10
PKI
PKI's Avatar
AW - Thanks. SST sounds like a good upgrade.
Travel safe. Pat
Old 04-23-2016, 08:42 AM   #11
AWCHIEF's Avatar
Images: 33
Found the old links. You can see how they are deformed. It looked worse when they were on the bars. I had to pound them out to remove. That actually straightened them out a bit. New link is a bit longer so might have to take up one more link when hooking up.
Name:	ImageUploadedByAirstream Forums1461422491.808484.jpg
MICHAEL
Old 04-23-2016, 10:36 AM   #12
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Good information, it's now on my to do list. Thanks
Hiho Silver is offline   Reply With Quote
Old 04-23-2016, 11:09 AM   #13
AWCHIEF's Avatar
Images: 33
I used nylon insert lock nuts. Guess I need to pull them off and use a dab of threadlock or not.
MICHAEL
Old 04-23-2016, 11:23 AM   #14
K.C. , Missouri
U-bolts
Chief,
Thanks for the followup. As a point of reference, I put a dab of grease on the u-bolt/first link contact point occasionally too. Don't know if it really helps or not....maybe it just makes me feel like I'm doing something worthwhile. I put a dab of grease on the hitch ball too.
Blue paint uwe Clearcoat, Exterior Paint & Trim 52 09-17-2014 07:41 PM
2004 Blue Airstream Land Yacht 30ft Class A Motorhome, Low Mileage! S2004 Blue Airstr eBay Watch Airstreams on eBay 0 03-22-2012 11:40 PM
Why do you have the Blue Beret? What is the Blue Beret for? PeeWee WBCCI Forum 12 02-22-2009 10:55 AM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
