Old 06-20-2016, 06:25 AM   #15
2010 25' FB Flying Cloud
Davenport , Iowa
when I had my 30', the PO had welded a platform style rack to the rear and there was frame separation. I was a newbe at the time and didn't know the trouble it had caused.
One learns quickly.
mike
Airtandem is offline   Reply With Quote
Old 06-20-2016, 06:29 AM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
X3.
A poor idea that can be made worse with the counter-weight scheme, which masks the poor idea.
Doug and Cheryl
Old 06-20-2016, 11:21 PM   #17
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
Originally Posted by ROBERT CROSS View Post
IMHO....it is NOT a good idea to hang 200lbs off the rear of your 19FC.
Smaller, lighter single axle trailers are more prone to sway, especially if not properly set up, proper tongue weight distribution & sway control VERY important.
A rack on the front or roof of the TV... a better solution.
An aside...the welds are not the most professional I've seen.
Plus...
Work by an AS dealer does not automatically=quality or confidence.
Stream Safe....
But as a first time AS owner, I can only rely on the AS dealership. I knew it wasn't the best weld, but from visual view, it looked sufficient.
cazual6 is offline   Reply With Quote
Old 06-20-2016, 11:24 PM   #18
Stay CazuaL
cazual6's Avatar
Reseda , California
Originally Posted by dkottum View Post
X3.
It was the only solution I can could think of to be able to bring four bikes. Counter-weight may be an option, but the wife says no. So bikes will have to be inside the AS. The wife says no to the roof rack on the TV. Any other suggestions? Throwing the wife out is not an option :-)
Old 06-21-2016, 03:01 AM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I would recommend a call to Jackson Center directly and get their read on this. I can't imagine an authorized AS dealer suggesting such a mod let alone performing it. While I don't see a specific prohibition in my (2012) user manual, I do see warnings about voided warranty for mods not approved by AS, overloading, misloading, not observing capacity labels, etc. and that only AS can determine warranty claims (meaning, a buyer/dealer isn't authorized to do a mod without written permission from AS and then claim it doesn't void your warranty).
If the factory approved the rear hitch, that's great. If not, your dealer has some explaining to do.
Either way, I think you'll find the general consensus is that a rear hitch is not recommended for an AS.
Good luck and happy camping.
Old 06-21-2016, 09:04 AM   #20
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
With a Fiamma rack you could put two bikes on the back and then two more inside, vs all four inside. Might be worth a shot.
Wishing you the best in a tough situation, sorry the dealer's bike rack implementation didn't work out better.
Rocinante is our 2014 International Signature 27FB
Old 06-21-2016, 11:50 PM   #21
Stay CazuaL
cazual6's Avatar
Reseda , California
I appreciate the input. Whether it voids the warranty or not, it is too late. I hope nothing goes wrong that would have them deny any warranty issues.
Old 06-22-2016, 05:54 AM   #22
Gainesville , Florida
The hitch is okay, just don't put anything on it. You can use it to mount a grille after you setup.
Old 06-22-2016, 07:03 AM   #23
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Some Airstream dealers are very good and know what they are doing, others are nothing more than used car salesmen saying anything they need to to push the metal. Unfortunately, it's easy for a newbie to not know the difference and to follow the dealer's poor advice as was the case in this instance. Even if the Airstream's structure was designed to handle the weight of the bike rack and bikes on the rear (which it isn't) the shift in weight off the tongue would have serious negative results on the handling of the TV/AS combination (which it did.) I hope others who are considering welding a hitch received to the rear of their Airstream for a bike rack, generator or other item of weight will read the thread above and save themselves the trouble, the damage to their Airstream and possibly their lives as well.
Not sure why the OP will not consider a roof rack for the tow vehicle, but two other options I have seen are a rack that sits above the trailer's propane tanks (I believe that this is attached to the A-frame somehow) and the other option being to mount a hitch receiver on the front of the tow vehicle and placing the bike rack there.
Bob Martel
WBCCI# 5766
Old 06-22-2016, 07:42 AM   #24
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
This is good advice!
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 06-22-2016, 07:52 AM   #25
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by AnnArborBob View Post
snip.....
A fourth option is a modern version of the old fashion slimp dolly, that were popular in the '50's and '60's.
There are versions available to even carry motorcycles let alone four bikes.
Lots of previous threads on their possibilities (http://www.airforums.com/forums/f464...lly-87055.html)
martin300662 is offline   Reply With Quote
Old 06-22-2016, 08:48 AM   #26
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Many people have a hitch receiver mounted on the front of the TV and put the bike rack there. It shouldn't interfere with cooling air flow through the bike wheels.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 06-26-2016, 07:18 PM   #27
Stay CazuaL
cazual6's Avatar
Reseda , California
My other post has many advise on why this idea was bad. I fought it hard, but in the end, safety for me, my family and others is just not worth the risk. I have found this forum to be one of the most useful and have the most caring people I have ever come across. Most people would have just given up and let me be and MAYBE make the biggest mistake. But they stuck with me tooth and nail until they drove the idea into my thick head that I was wrong, or at least risky enough to not risk it at all.
Aside from that, I also wanted to see if my new signature will work.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
Old 07-01-2016, 11:32 AM   #28
Tustin , California
Dual Hitch
I think I'd go with a dual hitch on the TV.
The top receiver is used for the bike carrier.
https://www.amazon.com/Bicycle-Recei.../dp/B000P6CJ9O
HyOnLyph is offline   Reply With Quote
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
Bike rack on a Suburbban Les Gilliam Our Community 2 04-06-2003 07:25 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
