Old 10-20-2012, 08:30 AM   #1
Engie's Avatar
2007 19' Bambi
Tempe , Arizona
Bike hitch
Hey. Gang has anyone welded a hitch on a bumper of a Bambi to use to haul bikes? I am concerned about weight distribution and bottoming out going over curbs. should i be? If you have a hitch on a bumper do you have some pictures from the underside that shows where it was attached. Ideas and suggestions welcome.
Thanks engie the newbie
Engie is offline   Reply With Quote
Old 10-20-2012, 09:52 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The bumper on an Airstream will hold the vertical load of bikes but will not restrain the rotational force about the point of connection.
The picture shows how I transferred that load to the window frame. The rack is attached tot he bumper with 4 bolts and wooden blocks to match the couture of the bumper. I made small clips to attach to the window frame to accept the straps.
It has worked for over 10 years and more than 50,000 miles. However I am seeing some sag in the yellow arms.
ID:	170846   Click image for larger version
Name:	Bike rack clip.JPG
2004 Excursion 4x4
Old 10-20-2012, 10:09 AM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
The below link is the result of using Airforums Search menu with the Google search option. It will take you to a list of several threads on this topic. You will also find at least one thread on the back bumper hitch that Airsteam is now marketing for Airstream trailers.
Ken
airstream bike rack - Google Search
Old 10-20-2012, 06:27 PM   #4
Engie's Avatar
2007 19' Bambi
Tempe , Arizona
Thanks great information as always. Looks like the airstream rack installed by a dealer is the way to go.
Old 10-20-2012, 07:07 PM   #5
nilesrob's Avatar
Marietta , Georgia
Images: 12
Was just at Jackson Center last week and saw a number of AS's with the AS bike rack installed. No personal experience, but did talk with someone who has used it extensively - with high regards. My understanding is it runs around $600 (installed). The base is secured on the bumper, and is bolted into the back below the rear window. Looked pretty good, actually!
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
