Old 07-22-2018, 03:32 PM   #1
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Best Trailer Hitch Lock for Class V, 2.5 inch ?
I'm looking for a high security, dependable lock for my hitch ball mount. Price is not a major factor.
I have a 2.5 inch, Class V hitch on my RAM 3/4 ton and would like a locking hitch pin that is corrosion and theft resistant.
What have you found that fits the bill?
SilverWind is offline   Reply With Quote
Old 07-22-2018, 03:53 PM   #2
Adventure.AS's Avatar
Port Dover , ON Canada
I would recommend the BOLT 5/8" Receiver Lock. You can get one that can be keyed alike (by you) to your RAM ignition key. BOLT also makes padlocks and cable locks that can by keyed to your ignition key.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 07-22-2018, 04:36 PM   #3
SilverWind's Avatar
1968 17' Caravel
Unfortunately, according to their website, they don't offer one for the RAM 2500/3500 series. Good idea though.
Old 07-22-2018, 07:49 PM   #4
I found one for the Dodge Ram Pickup https://www.boltlock.com/vehicle_mat...BASE&year=2017
Ray B.
Old 07-22-2018, 08:59 PM   #5
2016 30' International
Florence , Alabama
I have one...
joshjack is offline   Reply With Quote
Old 07-22-2018, 10:55 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I just drilled out the hole a little bigger and use a padlock instead of a clip.
CRH is offline   Reply With Quote
Old 07-23-2018, 06:25 AM   #7
BOLT Receiver Lock
I think the OP is looking for a locking pin for his receiver, not the coupler. However, BOLT also makes a padlock that can be keyed to your ignition key and it fits through the coupler latch and is long enough to secure your chains when parked. You may not want to padlock your connected trailer to the hitch ball in case you need to quickly disconnect in an emergency.
Ray B.
Old 07-23-2018, 06:33 AM   #8
Florence , Alabama
You’re looking for one that says “RAM 2500” - it doesn’t. Just look under the Dodge Pickup section. They use the same key type for all of the trucks and some Jeeps; and it’s be right size too.
Hitch locks are weight rated, so you won’t necessarily see one that says “Class V”, but instead 2.5” receiver compatibility
Old 07-23-2018, 07:01 AM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
I was talking about my receiver pin.
Old 07-23-2018, 07:32 AM   #10
"I just drilled out the hole a little bigger and use a padlock instead of a clip."
You drilled out your receiver (the tube on your TV that the ball mount goes into) and the ball mount hole larger than 5/8"?
Ray B.
Old 07-23-2018, 07:59 AM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
No.....I drilled the existing hole in the 3 buck hitch pin out a little larger so I could put a padlock in the hole to secure the pin instead of a wire clip.
Old 07-23-2018, 08:26 AM   #12
I see, you were talking about the coupler lock, not the receiver locking pin.
Ray B.
Old 07-23-2018, 08:31 AM   #13
CRH
1995 25' Excella
xxxxx , xxxxxx
I was not talking about the coupler lock.....
ID:	317829   Click image for larger version
Old 07-23-2018, 08:43 AM   #14
Thanks, a picture is worth a thousand words. My original hitch pin doesn't have a hole, so I couldn't figure out what you were describing.
Ray B.
15 inch tires v 16 inch tires CEG Tires 29 07-28-2018 05:50 AM
15 inch vs 16 inch wheels goliad1 Wheels, Hubs & Bearings 42 10-24-2017 11:55 PM
2014 Classic tire/rim change from 15 inch to 16 inch ratchet Tires 32 04-06-2017 08:14 AM
14 inch or not to 14 inch wheels.. busboy 1961 - 1963 Bambi 0 08-25-2013 10:19 PM
16 inch wheel 7 inch width? Wiremanranch Wheels, Hubs & Bearings 2 03-24-2013 06:16 PM
