Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 04-29-2008, 02:54 PM   #1
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
"How tight is the WDH?"
I was asked the question two hours ago, "How tight are you making your WDH?" by the installer of my TV hitch. I took the car into him because my hitch is bending. My TV is a '71 Buick. The hitch was fabricated to span across the underside of the fuel tank with a box channel. The '66 Trade Wind tongue weighed about 650# two weeks ago with full propane and about 25 gals. of water. I use 1000# spring bars. I chose that size because the car weighs 4400# with a long deck and a longer than 'normal' hitch ball shank. When the bars are adjusted they are TIGHT with a little bend in them at the chain. I can't imagine using say 750# bars. That may be too springy. I think my problem is the long distance from the car axle to the trailer hitch. What do you think? 750#s? The hitch fellow is going to beef up my hitch.
Neil
Name:	Aug. 10 to Sept. 16 2007 027.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
Lake San Antonio, 10/07
'Cover Photo'
1966 Trade Wind
455 cid
Old 04-29-2008, 03:05 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Proceed as posted.
Originally Posted by FreshAir
... What do you think? 750#s? The hitch fellow is going to beef up my hitch.
I think you need the 1000 lb bars for your tow vehicle's suspension.
I also think that beefing up the hitch is the best approach.
Tom
Old 04-29-2008, 04:18 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Neil
The bending of your bars, is good.
That gives the rig some resiliency when hitting bumps, which is a good thing.
It's a "very bad" thing when the bars are hitting the A-frame.
The bars, under stress should be ball park, parallel to the A frame.
To correct the problem, in your case, is simply moving the ball mount so that it's tilted rearward.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 04-29-2008, 04:36 PM   #4
FreshAir
FreshAir's Avatar
Thanks, Andy. I have since this picture, taken last year, tilted the ball rearward. I then didn't notice the hitch support was bending down across and away from the bottom of the fuel tank. I tightened up one link and was puzzled why I had too. When I noticed that problem at our spring rally I loosen the chain back to where it was orginally. The bar 'looked' in a better position but the weight distribution to the TV front wheels lessened a lot.
Neil.
FreshAir #12407
Avatar;
'Cover Photo'
1966 Trade Wind
455 cid
GVWR...the "Law" or a "Guide"??? TomR Tow Vehicles 8 11-16-2007 06:23 PM
Are "Airstream Only" Parks Really "Silver Only"? JimGolden On The Road... 16 05-23-2006 07:40 PM
Hubcap search -- looking for "dog bowl" or "baby moon" hub caps yukionna For Sale & Wanted 5 07-26-2004 04:44 PM
