Old 02-22-2010, 10:28 PM   #1
1967 24' Tradewind
1979 25' Tradewind
thermopolis , Wyoming
Best hitch for frequent hookups
Hi All,
Bought a 66 Trade Wind far from home. The forum has convinced me I need a weight transfer hitch and possibly a sway control system to tow it home safely.
Because I plan to use the trailer in many unpaved situations and where I will drop the trailer and use the TV to travel about and then return and hook on and move, the question comes: Which hitch is the easiest to hook and unhook while offering good performance. Price is also a consideration for me. If it matters, the TV is a 2004 Dodge diesel 4wd.
Thanks, John
amoretti is offline   Reply With Quote
Old 02-23-2010, 12:56 AM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Go to the 'hitch' section on the forum to see hundreds of post regarding this subject - or do a search....
We've recently been kicking around this subject again...
http://www.airforums.com/forums/f464...ion-60867.html
We use an Equil-i-zer WD hitch, and have found it the absolute easiest to hook/unhook - it doesn't have chains at the rear end of the bars - the square bars rest on 'L' brackets that are bolted to the trailer frame rails...
You can see their product info here: Equal-i-zer® Hitch - The “American Original” with 4-Point Sway Control™ and Weight Distribution
Hope that helps....
Ray
Ray & Pat; Morada, CA
Old 02-23-2010, 05:44 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I respectfully decline...
Good luck in your search....
Stream Safe...
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 02-23-2010, 11:00 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
The good news is that since you will be hitching and un-hitching frequently then it doesn't matter which appears to the least- or most complicated; you will quickly become so expert in whichever one you choose that "easy" is no longer a criterion for hitch choice.
So, buy the best one you can afford. I use and recommend the Hensley.
Pat
pmclemore is offline   Reply With Quote
Home RV pad with hookups considerations? aomastu Full-Timing, Winter Living & Workamping 34 01-01-2018 11:37 AM
dumb question - water hookups stu.cruz Fresh Water Systems 16 12-16-2009 04:04 PM
Internet / Satellite Hookups wtmark Computers, Internet & Satellite 58 01-21-2008 07:02 PM
Cable TV Hookups Devoman Electrical - Systems, Generators, Batteries & Solar 7 03-20-2006 11:11 AM
Setting up hookups at home rluhr Winterizing, Storage, Carports & Covers 26 05-10-2005 05:11 AM
