Old 03-13-2014, 06:31 AM   #1
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Bent Reese SnapUp Bracket
Hi need expert answers..
- i have 2006 19' Bambi
- drive. 2013 2500 Suburban
- reese weight bars
- reese friction sway control bar on one side.
- my curb side snap up is bend and somewhat pushed up fron channel
Questions
- what weight bars should I be using for my car and size Airstream? I know if they r too heavy inside rivets can pop out.
- I take the friction sway bar off when backing up
- Should I take the weight bars off everytime I back up? That would require putting jack down, lifting whole TT/TV and removing. Then my car would not be straight and even.
- who would set my car to proper setup, Airstream dealer, Reece Dealer, or an RV dealer?,
- why did it bend?
Thank you for help....I travel alone and need to be as prepared and educated as possible. The car is new.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 03-13-2014, 08:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How about a picture of the bent part?
The bars should be 600lbs. for your rig.
Consider getting rid of the friction plate and getting the Reese straight line system so you don't have to remove things when backing up.
The only way to set up a Reese system is to do it your self. To do it right it takes far too long for a dealer to do it and thus they will not do it right.
If you want instructions PM me.
A less expensive and better way to go would be to install an Andersen system.
PM "munimula" he is in Rockaway and might be able to help
2004 Excursion 4x4
Old 03-13-2014, 09:38 AM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I had a bracket bend on me also. Not sure what caused it, but I had just come down the Wind River switchbacks in Wyoming/Utah. That experience is what pushed me to get a Hensley.
I purchased a couple and will send one to you if you still need it.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 03-15-2014, 07:07 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I had one bend years ago. The bolt that provided pressure to lock it on the A frame of the trailer loosened up with time. Backing the trailer at an angle put pressure on the bracket and it bent since it was not being held tight in the A frame.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-15-2014, 10:22 AM   #5
1981 31' Excella II
New Market , Alabama
It is not a bad idea to remove the load bars and any friction bars prior to backing at extreme angles. This would be at the limits just before something hits. The only time I need to do that is when I am backing in the yard where I don't have much room and the tow vehicle is almost 90 degrees to the trailer.
Perry
Reese hitch recall!!!!! lewster Hitches, Couplers & Balls 7 08-10-2011 07:34 PM
Equalizer vs. Reese dual cam road test dznf0g Hitches, Couplers & Balls 25 08-02-2011 06:30 PM
Reese Dual Cam help.. Janie Q Hitches, Couplers & Balls 2 07-06-2011 12:06 AM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Reese Part Number 26002->26102 thecatsandi Hitches, Couplers & Balls 28 04-19-2011 04:15 PM
