Old 01-28-2011, 06:36 PM   #29
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
finishing off the thread
After driving with the outfit for 3,000 miles I was able to get to a competent RV repair place in Las Vegas (Las Vegas Trailer Supply). I brought the problem
up to Steve, and he adjusted the hitch. I agree with SteveH in his post that
the hitch ball was too far forward. Steve (at Las Vegas) adjusted the ball
backwards, and the angle is now proper, so that the trunnions no longer can
contact the two cam assemblies. There were actually marks on the new
ones that resulted from contacting the trunnions. So now they don't.
The angle is large enough. The initial adjustment was set up at an RV place
where I bought the system. It was out of adjustment ever since.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Reese Pro Series SC WD/Sway control tetstream Hitches, Couplers & Balls 3 06-28-2011 10:20 PM
Is sway control bar necessary? 3/4 ton Diesel pulling a 19' Bambi? QwstnEvrythg Hitches, Couplers & Balls 31 11-08-2010 11:24 PM
Reese Dual Cam Sway Control with SOB WD hitches? Lumatic Hitches, Couplers & Balls 12 03-02-2010 10:24 AM
Reese friction anti-sway bar broke Phantom Hitches, Couplers & Balls 18 11-28-2009 11:02 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 07:17 AM
