Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 12-19-2010, 11:53 AM   #21
1975 31' Sovereign
1981 31' Excella II
longview , Texas
Round Bar
Is this interference a problem with the round bars and standard large 1 1/4 nuts?
AirDD is offline   Reply With Quote
Old 12-19-2010, 01:17 PM   #22
HowieE's Avatar
Princeton , New Jersey
Images: 12
The first picture shows the bars as you are going straight. Note the clearance.
The second picture shows the bar as you back up in a tight turn. Note the fact that the bar has touched the yoke. Any additional turning would bend the adjustment bolt outwards from the yoke. This picture is of the inside bar only because I did not take one of the outside bar. This condition is worse with the outside bar in a turn because the bar can raise higher off the cam because of the longer tail to the rear of the bar. That length is a safety factor to keep the bar from dropping off the cam. But that is what causes the problem.
I ground material off the yoke to increase the clearance and thus reduce the point of contact.
The shallower the angle of the yoke to the frame the greater the likely hood of contacting the bar.
There is No way this type of hitch will ever contact the shank or shank nut unless you have buried the trailer in the back half of the TV. That a total of both the TV and the trailer.
As noted before I can not comment on the Draw Tight Round bar system because I do not have one to analyze at this time. But I suspect the same conditions will exist
Name:	small straight.JPG
ID:	117316   Click image for larger version
2004 Excursion 4x4
Old 12-20-2010, 12:11 PM   #23
2016 30' Classic
Sammamish , Washington
Originally Posted by HowieE View Post
I think we need to define the type of hitch in question here. If it is a Draw Tight bent arm type it could be possible to hit the nut since the bars mount forward of the nut. If it is a Reese Straight Line or Duel Cam Trunnion type it is not possible to hit the nut since the trunnions mount to the rear of the nut. My comments have been directed to this type of hitch since the name Reese was originally noted in the thread.
Both type are now sold under the Reese name since Cequent Towing bought Reese.
I have the Reese Strait-Line hitch with 1200 lb trunnion bars (66074) which consists of the Trunnion Bar Weight Distrubution Hitch (66022) and the Dual Cam HP Sway Control (26002). The center of the trunnion pin holes on the 66022 ball mount are approximately 1" forward (toward the the tow vehicle) of the center of the hole for the ball shank. Therefore, the trunnion can (and does) contact the ball jam nut for 2-5/16" balls with a 1-1/4" shank in tight turns.
NOTE: The last sentence in step 3 of INITIAL SET-UP (INSTALLATION INSTRUCTIONS Trunnion Style Weight Distrubution Kits) reads, "A thin jam nut (.72" thick) should be used on standard ballmount to prevent interference with spring bar trunnion."
PJohnson is offline   Reply With Quote
Old 12-20-2010, 12:35 PM   #24
2016 30' Classic
I do not have any experience with round bars but looking at the installation instructions, I could not find reference to a "thin jam nut." Furthermore, since the bars mount through the bottom of the ball mount and do not have trunnions (the part that the flat spring bars are mounted in) it appears that it is impossible for the round bars to contact the ball jam nut.
Hopefully, someone who has first hand knowledge about round bars can give you a more definitive answer.
Old 12-20-2010, 02:19 PM   #25
reo
2008 19' Safari SE
satellite beach , Florida
Maybe It's the photos, but with a minimum of 5 links of the chain in use, as per install. instructions, your yokes would be at a greater angle from the frame affording you more clearance.
reo is offline   Reply With Quote
Old 12-30-2010, 01:35 PM   #26
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Originally Posted by hshovic View Post
On our last trip in Colorado, I backed into a flat site on National Forest. I have done this many times (49,000 miles worth).
I had to back in at an angle, and the trailer went in fine. I did notice the trailer dipped a bit, when my front truck wheel went off the pavement (about 2 inches).
The wife was outside and did not hear or see anything unusual.
However, the next day, I did notice something unusual. Both the cam and the cam arm were bent! Of course the trunnion was then off
the cam bottom, and I could feel the trailer sway down the road.
We had it replaced in Colorado Springs, at a Camping World where they did it
quick and right. They also had never seen this before.
I emailed Reese about it, but no coherent answer so far.
Anyone else seen this?
Send this picture to Dan Miller (Dan's Hitches, Elkhart, Indiana) Dan has dealt with Reese nearly as long as Reese has been in business. He is probably the #1 hitch guy in the United States. I'm sure he could tell you why it happened and what to do to avoid it in the future.
Larry
Larry C is offline   Reply With Quote
Old 01-25-2011, 10:51 AM   #27
rogerdodger's Avatar
1974 Argosy 28
Fresno/Clovis , California
I've been reading this with interest. I have the round bars, and there is no way they can contact the ball jam nut.
However, the problem Howie shows, with contact on the arm, can happen, and should be tested in a tight turn with an observer, then fix it like he did, before you damage them while backing in tight turns.
Roger
rogerdodger is offline   Reply With Quote
Old 01-26-2011, 06:45 AM   #28
SteveH's Avatar
Common Sense , Texas
Someone who often tell us he knows all there is to know about Reese Dual Cam hitches is suspicously absent from this thread.
Regards,
Steve
Old 01-28-2011, 05:36 PM   #29
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
finishing off the thread
After driving with the outfit for 3,000 miles I was able to get to a competent RV repair place in Las Vegas (Las Vegas Trailer Supply). I brought the problem
up to Steve, and he adjusted the hitch. I agree with SteveH in his post that
the hitch ball was too far forward. Steve (at Las Vegas) adjusted the ball
backwards, and the angle is now proper, so that the trunnions no longer can
contact the two cam assemblies. There were actually marks on the new
ones that resulted from contacting the trunnions. So now they don't.
The angle is large enough. The initial adjustment was set up at an RV place
where I bought the system. It was out of adjustment ever since.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Reese Pro Series SC WD/Sway control tetstream Hitches, Couplers & Balls 3 06-28-2011 09:20 PM
Is sway control bar necessary? 3/4 ton Diesel pulling a 19' Bambi? QwstnEvrythg Hitches, Couplers & Balls 31 11-08-2010 10:24 PM
Reese Dual Cam Sway Control with SOB WD hitches? Lumatic Hitches, Couplers & Balls 12 03-02-2010 09:24 AM
Reese friction anti-sway bar broke Phantom Hitches, Couplers & Balls 18 11-28-2009 10:02 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
