Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 07-25-2008, 07:52 PM   #1
2007 28' Safari SE
Little Rock , Arkansas
Bargman 12V Breakaway Switch Burned
While hitching up my Safari for a quick weekend getaway, my Bargman 12V breakaway switch caught fire and burned with the pin in. It's probably 2 years old. The time between securing the umbillical cord around the receiver and plugging in the pin was only seconds. I had to use a fire extinguisher on it several times as it kept smoldering. While the unit burned the brakes were engaged. When I finally succeded in extinguishing the fire, the brakes released. Anyone had a similiar experience?
mmmtob is offline   Reply With Quote
Old 07-25-2008, 07:57 PM   #2
Naples , Florida
I haven't seen this in the Bargman switches, but I have dealt with it on SOBs that were not wired properly. You had a dead short within the switch that grounded to the frame and pulled the full amperage from the battery into the switch. The wire gauge within the switch could not support this big amp draw, overheated and ignited!
I would contact either Airstream or Bargman for a replacement switch under warranty, AND I would replace ALL of the wiring right back to the battery.
PS: Welcome to the Forums!!!
lewster
12v
Breakaway switch. FreshAir Brakes & Brake Controllers 44 02-12-2007 11:18 AM
Breakaway Switch PunkZTT Brakes & Brake Controllers 24 05-02-2006 11:48 PM
breakaway switch aeriqua Brakes & Brake Controllers 2 01-09-2006 06:48 AM
Theo Bargman breakaway switch - old style C Johnson Brakes & Brake Controllers 2 06-06-2005 12:01 AM
Burned 4 way light switch silvrtwinkie Electrical - Systems, Generators, Batteries & Solar 1 08-06-2004 09:56 AM
