Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-04-2006, 04:48 PM   #1
Steve Heywood
Steve Heywood's Avatar
Profile:  1997 30' Excella
Lynden , Washington
Ball Height Question
I'm replacing my worn out Eaz Lift with a Reese Strait-Line. Problem is I can't seem to match my current ball height (19 1/4" unloaded). Depending on the shank I'm either an inch lower or about 3/4" higher.
I was thinking that slightly lower might be better but I'm not sure I want to go that low.
Ideas, comments?
Steve Heywood
Lynden, WA
2005 Ford F250 CC Powerstroke
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 10-04-2006, 05:10 PM   #2
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
All the Reese adjustable shanks I've seen had 1" hole spacing , are yours 1 3/4" ?
ticki2 is offline   Reply With Quote
Old 10-04-2006, 05:33 PM   #3
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
When those heights are stated are they to the top middle ot bottom of the ball?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 10-04-2006, 05:38 PM   #4
skykingpilot
Profile:  2005 19' Safari
Duluth , Minnesota
If you have to go one way or another, I would recommend lower than higher. Still wtill want to assure that you are at least very close to level wither way. Having said that, being a touch low in front gives youa scooch of extra room btween bumper and ground. I have a SLIGHT nose down attitude and it works fine for me. When I say SLIGHT I do mean SLIGHT. I think i am no more than about 1/2 in low relative to optimum level. Still... gives me that margin on bumper. Kind of glad to have it to tell you the truth. Have not scrapped the bumper (but I am paranoid about such things so I am extremely careful). FWIW... I wouldn't worry.
skykingpilot is offline   Reply With Quote
Old 10-04-2006, 07:29 PM   #5
mustang
mustang's Avatar
Profile:  1971 31' Sovereign
Kent , Ohio
Hitch measuring
I was always told and have used the 19 and a half measure from top of ball to ground I will also add a garage floor is sloped and will throw off the measurement. 19 1/2 has never done me wrong. Good luck
mustang is offline   Reply With Quote
Old 10-04-2006, 09:44 PM   #6
Steve Heywood
Lynden , Washington
Further thoughts and measurements
I always measure to the top of the ball.
The difference between the holes on a Reese shank are 1 1/4".
With my current ball height my trailer is SLIGHTLY nose high. I'd like to lower it about 1/2"
I bought a dropped shank because I didn't think that 1 1/4" of drop (the standard cast Reese shank) would be enough. I re-measured the dropped shank with the platform level and the drop is 1 7/8". I had previously measured it with the platform angled back and it was nearly 2 1/4". I ordered the standard cast shank last night. Between the 2 different shanks I'll get the ball height exactly where I want it.
When I look at the picture of my previous Reese Dual-Cam hitch (in my photos) the platform is nearly level.
Steve Heywood
Lynden, WA
Old 11-04-2006, 03:51 PM   #7
ldetsf
Profile:
I have a 91 25' Excella 1000 and AS told me the required ball height which I immediately wrote down and lost. I think it was 18+ or 19+ but don't remember. It's not the height shown with the current models. My vehcle ball height is 22 1/2" so I need to know what size drop shank to buy. Anyone know for sure? Thanks
ldetsf is offline   Reply With Quote
Old 11-04-2006, 04:32 PM   #8
jimmickle
jimmickle's Avatar
Profile:  Marion , Iowa
I would suggest that you get the loaded trailer on a flat surface. Adjust the tongue jack so that the frame is the same distance from the flat surface front and rear. After you have done that, measure from the top of the coupler to the flat surface. That is coupler height. Reese says adjust the ball height to 1/2 to 1 inch higher than that dimension. Any dimension in a chart is only approximate. Trailer load, axle condition, etc. affect coupler height so actually measuring your unit is the best way to set up your hitch.
Note, the flat surface doesn't need to be level, just flat.
jimmickle is offline   Reply With Quote
Old 11-04-2006, 05:51 PM   #9
Pat370
Profile:  Hastings , Minnesota
Ball hight
If you have Radial tires on your trailer then your ball highr should be 18 3/4 inches from the ground when unhooked.
Then adjust your lift bars up to be the same hight when hitched up on level ground. This is from the top of your ball.
Good luck,
Pat370
Pat370 is offline   Reply With Quote
Old 11-04-2006, 06:18 PM   #10
flyfisher
flyfisher's Avatar
Profile:  2004 30' Classic
Lancaster County , PA & MT
I guess your ball mount does not tilt backward like mine does on my Reese hitch?
I've had 2 Reese hitch heads and both were the tilt type, which helps achieve a level hook-up.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 11-04-2006, 06:23 PM   #11
AlbertF
Profile:  1975 27' Overlander
In the Kootenays , BC
I would start on the high side with the ball vertical, and tip it back until the height is right. That should get you close, anyway.
This whole discussion demonstrates one of the advantages of the old weld-together ball mounts.
AlbertF is offline   Reply With Quote
Old 11-05-2006, 02:06 AM   #12
ldetsf
Profile:
Got another question: If I use actual measurements, my ball height is 22 1/2" and the coupler height should be 19 1/2" if I remember correctly. So, if we assume that's correct, can I drive approximetly 1000 freeway miles with the trailer front raised accordingly and expect that I won't mess something up stupidly? The reason I'm contemplating this is that I'm driving to another state and pick up a proper hitch on the way. I have towed under the above conditions already for about 150 miles without incident. Look forward to your thoughts.
Old 11-05-2006, 04:58 AM   #13
AlbertF
A neighbour brought my trailer home for me, and it was towed slightly nose-high because the hitch setup was done in less than ideal conditions with hand tools.
The tow vehicle was a later model Yukon XL. We had an appropriate amount of tension on the bars. It towed OK except there was a steady and predictable sway at speed that required extra clamping pressure on the friction control to (mostly) eliminate. Towing level, I am certain that the sway would have been non-existent. The rear tires also ran considerably hotter than the front. It was almost like we were towing a single axle trailer. (It's good that it had Load Range D tires inflated to maximum pressure, which is good for a rating of 2460 lbs per tire, enough to handle the about 4800 lbs empty weight.) We also towed 150 miles this way.
Unlike linked leaf spring axles, the rubber torsion axles are completely independent, and don't transfer any load between them. It is quite important to have the trailer close to level to avoid potential problems like mine.
Old 11-05-2006, 06:30 AM   #14
dwightdi
McHenry , Illinois
All good advice here. The tire temperature will tell you alot about whether you have set up the rig properly on a dual or triple axle unit. Before you start to pull at sustained high speeds keep your tire pressures up and feel them frequently to see how they are bearing the load. You can easily sense as little as 5 degrees difference in the tire temperature. Also check the temperature of the individual wheel bearings. The proper setup of ball height and weight distribution bar settings will result in completely uniform temperatures in the trailer tire temperatures and wheel bearings. Go slow and listen to what the trailer is telling you.
airstream height Earl 1981 - 1983 Excella 1 09-01-2003 09:35 PM
tow ball size iguana Hitches 2 10-03-2002 11:39 AM
Tire sizing question caadoptees Tires 5 07-02-2002 10:19 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
