Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 08-21-2007, 10:16 AM   #71
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Originally Posted by WestMichCamp
Yooper, after reading through this post, I have to give you credit for putting up with all of the "advice" you were given on here in regards to your Honda TV. I am not sure if you have noticed, but there are many people on here that like to quote specs and tell people why they can not do something, based on the "OEM Specs for their Vehicle" But in this case everyone suggested you ignore the OEM and do what they thought was better and safer.
It appears that your OEM is qualified to tell you how much you can tow, but they are not qualified to tell you how to do it with the vehicle they designed, but the people on here are qualifed to tell you. I got a chuckle out of seeing all of the "experts" on here give you gloom and doom strories about something they know nothing about. Towing with a Honda Ridgeline.
If you were towing with a Suburban, one of the favored tow vehicles on here, then I would say they do have a lot of hands on experince, and would be considered "experts". I had to laugh when one poster said that your 40 years experience pulling a pop up and a boat, ment you had no expereience pulling a travel trailer, and counted for nothing. What a joke, towing experience is experience. Just becasue someone has pulled a travel trailer, one, does not mean that they are good at it, or two, they are even a good driver. Many towers drive very little except on vacation, and many of their towing issues are more to do with their inabilites to handle road conditions and other vehicles, than the tow vehicle it self. Most, if not all, accidents are the result of driver error.
I hope you are enjoying your Reese system for your vehicle, that is the same one I purchased. I also pull with a less than favored tow vehicle, a Ford Bronco. I pulled it home, over 150 miles with the PO hitch, with no sway control on I 96 and I 696 , on a windy day, and had no issues. The Bronco is more stable with my Argosy on it than with out. Most of the credit goes to the Argosy though, since I passed many travel trailers being towed by the favored Suburban, weaving all over the place.
Next summer we plan to make a trip up to TQ Falls, there are some really nice state parks in the UP.
WMC, Yooper “asked” for advice, he did not “put up” with unsolicited opinions. Based on the data he supplied for his AS and TV, many experienced folks here as well as the manufacturer of his TV, suggested that this scenario would be near (if not over) his TV’s capacity. This is not the preferred position to be in, not the safest way to travel and is illegal. Had he asked for advice on a different combo, with more favorable ratios, there may have been a very different response. Yes we all have our brand loyalties, but would not hesitate to give the stamp of approval to any safe set-up. Were someone with an overloaded vehicle to get in an accident, you would be found at fault. As he already owns the vehicle, and may not be in a position to upgrade at this time, he chose to take his chances and try out this combo. Did you stop to think there may be a reason there are not many folks here towing AirStreams with such a vehicle? To date, it appears that he has been safe. I and many others would not feel comfortable traveling at near capacity. When someone does try this, gets away with it a couple of times, and then comments “it was fine” it is usually because they have no other comparison. If you towed your Argosy with a ¾ ton (and I am NOT suggesting you need one) I am pretty darn sure you would not want to tow with anything else again. Having more TV than you need provides a level of safety and comfort difficult to measure.
And yes, there is a significant difference between towing a popup or boat, and towing a travel trailer. The physics of towing a high profile vehicle, with great surface area, can make for some tricky dynamics. Most vehicle manufactures will reflect this in publishing one set of numbers for boat towing, and another rating for towing TT’s.
There will always be naysayers, and most of us need to learn by our own mistakes. For the most part, the folks on this board try to make suggestions in the name of safety first, and then comfort second. Hopefully, no-one will be hurt or killed along the way.
Good luck to you both.
Bill
Life is Good-Camping all around New England
BillTex is offline   Reply With Quote
Old 08-22-2007, 03:59 PM   #72
Profile:  1973 24' Argosy 24
Grand Rapids , Michigan
You missed the point
Bill
The main discussion on here did not have anything to do with the towing capacity of the TV, most of it centered around the fact that his OEM suggested he not use a WD hitch. Nothing was stated by his OEM that he was exceeding the capcity of the TV. He was not exceeding any recommendations of his OEM, the only thing he was doing, based on everyones advise was using a WD hitch, which was not recommended by his OEM.
What happens if down the road, he has an issue with his tires on his TV wearing in an odd pattern, or there is some issues with vehicle alingment, and they see find out he has been using a WD hitch? He is screwed, there is a reason they do not recommend them, but wait, they don't know what they are talking about, but everyone on here does.
You say he chose to take his chances and try this combo. What chances? People take chances everyday when they pull a travel trailer. You make it sound by even doing this he is being unsafe, which is not true. Why is this not a safe set up? Facts, not opinion please.
Lets see, take the number of Bambi's produced that his vehicle is rated to pull, times the number of Ridglines produced, and compare that to the number of Airstreams produced, and the number of Suburbans, GM anf Ford Trucks produced over lets say the last 30 years. I think you are able to do the math. Even if it was one of the best TV's out there, the numbers would still be low due to the number of Ridglines that have been produced.
As far as more power is better and safer. As long as your TV has the capcity rating that is not exceeded by the TT and you are looking at the same vehicle only heaveyer duty, then the only real advantage you have is that it will go faster with the TT attached to it. More power over what is needed to tow a vehicles safely, is just that more power, not added safety. There is a reason most vehicles in the ditch when it snows are SUV's, they can go faster in the snow, but they can not stop any faster. Your comment makes no sense in regards to added safety.
I am not saying he has the best setup, but what I have seen on here, if its not a suburban, or a HD truck, its not safe or adequate by most peoples standards on here. If that was true, we would all have Diesels and HA hitches.
Your right, he asked for adivice, and everyone gave it to him on why he needed a WD hitch for his Ridgline, but think about it, no one really knew what they were talking about since no one on here had any experience with the Honda to know if the OEM was correct or not.
Everyone loves to thow "safety" around on here and that is the justification for everything. Just because you play with Tiger Woods clubs, does not mean you are as good as Tiger Woods, you just have the same equipment, and you will find he is just better at using it. He could beat you with starter clubs, just like a good driver with a "less than ideal" setup up is much better and "safer" than a average driver and a "good" setup, regardless how many miles they have driven with a TT behind them.
WestMichCamp is offline   Reply With Quote
Old 08-22-2007, 06:44 PM   #73
Profile:  1976 25' Caravanner
Campton , New Hampshire
Seem to remember the original title of this thread was "Ball height question?". What happened?
ticki2 is online now   Reply With Quote
Old 09-18-2007, 12:06 PM   #74
Yooper's Avatar
Profile:  2006 16' Safari
Ramsay , Michigan
Hello, WestMichCamp!
I have continued to enjoy towing with the Ridgeline and just finished a 2200 mile round trip to New York's Catskills. I love the Reese WDH, and really can't imagine towing without it. The folks on this forum are sometimes "rough and tumble," but at least you know what is on their minds.
I have not installed the Reese anti-sway system, as I will have to do some cutting and welding to move the Bambi's battery box to get it installed properly. Frankly, I have travelled enough miles in enough conditions to question whether the anti-sway system is needed with this combination of trailer and TV. No issues whatsoever with swaying.
TQ falls is on the eastern end of the U.P., we live on the western end near Ironwood. If you get over to this end, I would recommend you take a trip out to Black River Harbor, on Lake Superior. Gorgeous National Forest Campground on a bluff overlooking the lake/harbor. No services on their sites, but they do have a dump station. And every site is separated by tree lines. If you like falls, they number one after another as you come down the Black River Valley to the lake. They are marked, and have developed access points. Some great drops.
The shoreline for Lake Superior is undeveloped for many miles each way.
Worth a stop!
TTYL,
Yooper
Yooper is offline   Reply With Quote
Old 09-23-2007, 11:48 AM   #75
shantz's Avatar
Profile:  1979 25' Tradewind
virginia beach , Virginia
need help
gents,
I have a draw tite drop hitch with sway bars. Just got it on my TV and when hooked to the trailer the tongue is 1" higher in the front than the rear.
I am almost level and do not have any more adjustments to drop it down.
Do you think I am ok at only 1" high on the tongue? or should I buy a longer drop hitch?
shantz is offline   Reply With Quote
Old 09-23-2007, 12:44 PM   #76
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
shantz
Here goes:
Ball height is very inportant, more important than on a trailer with leaf springs and an equalizer link between the springs.
On our airstreams with the torsion springs there is no equalization of weight between axles, there fore the ball height is what you adjust the balance of weight between the front axle of the trailer and the back axle of the trailer.
The best way to establish ball height is to take your unit to a CAT scale and play with ball height and trunion/round bar/equalizer bar tension until you have close to the same weight on all four axles on both vehicles (Two on the tow and two on the trailer). If you look at my pictures you will see that the trailer seems a little off, but the weight on all four wheels is within 100 lbs of one another.
If you want let me know and I will be happy to go with you to the CAT scale on Rt460 in Suffolk and do the adjustments. I live in Norfolk.
Beginner
Beginner is offline   Reply With Quote
Old 09-23-2007, 01:58 PM   #77
shantz's Avatar
hello Beginner,
I just might take you up on that offer. I am going to try Dodd RV this week to get a longer drop hitch shank. I just shelled out a wad of cash to Truck Accessory center in Moyock for the one I have and wish I could do an exchange for a longer hitch.
I didn't see which photo you were describing where you had a slight increase or decrease but still had each axle within 100lbs.
also, did the truck scale let you stay there and adjust? and are you referring to thee truck scale near the airport ?
Old 09-23-2007, 04:53 PM   #78
Norfolk , Virginia
Images: 11
Ball Height Question
shantz
The scale out by the airport is a State of Virginia Truck weighing station. DO NOT GO THERE.
The CAT scale is on 460 at just off the by pass on the right. Its actually a Miller Mart/Truck Stop/CAT Scale.
I called them ahead of time and talked to the person there and explained to them what I wanted to do.
I was told that I could use the back lot and I took pains to stay out of the way of the trucks (people making a living).
Its $10.00 for the first pass and $1.00 for subsequent passes within the next 24 hours.
Once I finally got the weight on axles equalized I rejusted the Reese Dual cam anti sway saddles (as they were off when I had finished) while I was there. There is plenty of room.
The best picture I have is an accident, I was caught at someone elses caravan. Go here
TCT Photo Gallery - The Participants - Powered by PhotoPost
page 2 pic 393.
Thats my tow vehicle and trailer in the background. It looks a little tounge low but the weights are right.
It will have to be a weekend as I still work.
Beginner
Pingbacks are On
airstream height Earl 1981 - 1983 Excella 1 09-01-2003 09:35 PM
tow ball size iguana Hitches 2 10-03-2002 11:39 AM
Tire sizing question caadoptees Tires 5 07-02-2002 10:19 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
SEO by vBSEO 3.1.0
