Old 04-03-2011, 09:16 AM   #1
2009 16' International
Verona , Wisconsin
Ball Height Issue, 16' International
Hi All:
After searching the forum for quite a bit, I am still at a loss as to what I need to do to get the right ball height since I changed my TV.
I recently swapped out my TV from a Toyota FJ Cruiser to a 2011 Toyota tacoma, which drastically changed the height of my tow ball. As the pic attached shows, I am about 6" too low (with the old set up) on the tacoma. I want to keep my current sway control setup etc, but not sure what modifications I need to make to get the ball in the 16-17" range. The hitch on the tacoma is exactly 18", and as you can see the old one takes it awfully close to the ground. Thoughts? Is there a straight bar that I can purchase that will accommodate the sway bar attachments?
Thanks!
ID:	126036   Click image for larger version
mico75 is offline   Reply With Quote
Old 04-03-2011, 10:08 AM   #2
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Yes there is a straight head from DrawTite or Reese that should make the ball height about 19 or 20 inches and should come out about rite when the tongue weight is applied.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-03-2011, 11:13 AM   #3
Verona , Wisconsin
Thanks. Do you have any links that would show me the product(s)? I'm not finding the straight bar that has the right sway bar attachment points.
Old 04-03-2011, 11:33 AM   #4
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I purchased something like the one shown here
Reese Weight Dist Shank - 12-1/4" Long - 2" Drop to 6-1/2" Rise - 1,500 lbs TW Reese Accessories and Parts RP54970
Check it out!
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 04-03-2011, 11:58 AM   #5
reo
2008 19' Safari SE
satellite beach , Florida
What about removing the ball mount from the shank, and turn the shank 180 degrees so it is pointing up instead of down and replacing the ball mount to a more suitable height.
reo is offline   Reply With Quote
Old 01-09-2012, 07:25 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
... and, it looks like you have at least one more mounting hole for adjustment as well ...
16' international
Does NADA have any bearing on reality? International 23D smeghead Trailer Values 20 04-13-2011 01:18 AM
Adjusted the ball and hitch today Lucky Dog Hitches, Couplers & Balls 15 03-30-2011 11:03 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
How and When to Measure Hitch Height lcurrie Hitches, Couplers & Balls 9 12-30-2010 01:59 PM
