Old 04-10-2006, 06:39 PM   #1
Alden Miller's Avatar
1993 34' Excella
, Maryland
Ball Height ??
My wife has cleaned up the Airstream in preparation for our first trip. I am looking for my manual to check what height the tow ball should be at. I just installed an easy rider air hitch and I am trying to get the height correct.
I measured where it was on my fixed hitch and set it on the air hitch so it would be at the same height. With all the weight of the trailer on the ball I am at 17 1/2" to the top of the ball. I seem to remeber this is about right. Can anyone confirm this?
The trailer looks level to a little bit nose low (although I have not pit the Weight Distribution bars on yet). Does this sound right?
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 04-10-2006, 07:03 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
As you can see at Airstream FAQs it looks like they're saying 18.75". I've seen things like that is to the top of the ball before you hitch up... which is nearly meaningless due to variable squishy-ness of suspensions. Are the tires the same size as original (more than likely). Best thing to do is try something close to the recommended height (or anything really), engage your WD bars and stand well back and look at it. Better yet, take a picture and post it here.
Measure to the top of the TV's wheel enclosure sheet metal before you hitch up. With WD properly engaged the body of your TV should settle equally front and back. Cinch up your WD a bit (links on a chain?) until it gets close to settling equally -- nothing is perfect y'know. If the trailer then looks high at the nose I'd consider lowering the ball a bit since you do have a pretty stiff suspension. Then post a picture and ask the experts here what they really think ...
And Alden -- a belated HAPPY BIRTHDAY!! Hope you have a fun trip.
5 meter Langford Nahanni
Old 04-10-2006, 07:42 PM   #3
1993 34' Excella
, Maryland
Just remember, no matter where you go, there you are... I like your tag line!
Is that height before the weight is put on the ball or after? If it's after then I am about an inch and a quarter low (probably one hole on the hitch). I've got to find that book. I checked where my wife said it should be but found nothing.
I got the air hitch because of the suspension and the discussions I've read here about beating up the trailer with it.
Thanks for the belated birthday wishes!
-Alden
Old 04-10-2006, 07:49 PM   #4
I've read it is the height to the top of the ball before you engage the hitch. There are so many variables I heard some speak to the greater importance of the following:
1. Equal settling of the TV front-to-back to gauge proper WD setting.
2. Then don't want the Airstream looking like it's traveling nose high.
I'm ready for any further comments from other members here ...
Old 04-10-2006, 09:17 PM   #5
WayWard Wind's Avatar
2004 25' Safari
You might look here for answers
I've got a set-up file from www.rvtowingtip.com/hitch-setup.htm, which gives pretty detailed steps for setting up the W/D. you may find it to be help.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-10-2006, 09:33 PM   #6
Hey Al -- Beautiful weather today! First PaulaFord, now you changing your ASForums mantra. How will I keep up with it all?
That rvtowingtip.com link might be dead ... Do you have another URL source that is working?
Old 04-10-2006, 09:43 PM   #7
2004 25' Safari
It was so nice today, that for a moment I thought I was in Minnesota. I'm sorry, but that url was all that was on my sheet. I'll do some surfing of my favorites. I'm thinking it's on there, if not an address would get a copy to whomever would want one. It's 4 pages (both sides) long and really detailed.
Best,
Bogfrog & Mr. Turbo
Old 04-10-2006, 10:07 PM   #8
2004 25' Safari
Thumbs up It's alive!!!!
Hey Canoe---I just typed in the url and the site came up o.k. Lots of other good info there if you go to the home page. Once again http:www.rvtowingtips.com/hitch-setup.htm. Should be a go.
Best,
Bogfrog & Mr. Turbo
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Airstream Height Earl Winterizing, Storage, Carports & Covers 25 03-22-2008 08:34 PM
Airstream height Earl 1981 - 1983 Excella 1 09-01-2003 09:35 PM
tow ball size iguana Hitches, Couplers & Balls 2 10-03-2002 11:39 AM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
