Old 02-07-2017, 12:48 PM   #1
dlenloe's Avatar
Tomball , Texas
Ball and hitch popping
We just picked up our airstream yesterday and there is a terrible popping when making a turn. It does sound like it is the ball popping in the hitch casing. Is that normal?
dlenloe is offline   Reply With Quote
Old 02-07-2017, 01:30 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
What brand of weight distribution hitch do you have? Some brands are quiet. Equalizer is known for making noises when turning. I have an EAZ Lift Elite with two friction bars. The friction bars are noisy.
SSquared is offline   Reply With Quote
Old 02-07-2017, 02:03 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Reese Dual Cam hitches make noise.
You can also sometimes hear popping on acceleration and deceleration if the shank to receiver opening is sloppy.
What are you using, WD or Ball only hitch?
Picture would be helpful.
2004 Excursion 4x4
Old 02-08-2017, 06:35 AM   #4
dlenloe's Avatar
Tomball , Texas
I have a Recurve 6 with the bars coming over the top rather than below like the Equalizer.
Old 02-08-2017, 06:40 AM   #5
dlenloe's Avatar
Tomball , Texas
Since I am new at this, does WD mean weight distribution hitch? I have the Recurve 6. The dealership said it is the bars making the noise but it does look like the bars are stressed when turning. I have watched them operate while one of us drives.
Old 02-08-2017, 10:43 AM   #6
Sioux Falls , South Dakota
Since this is a new set-up, check all adjustments and make sure that all is at proper tightness. For example, is the nut on the bottom of the ball tight? Are all mounting brackets, bolts, etc. tight? A bit of lubricant on the ball can help, too.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 02-08-2017, 11:48 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Grease them.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-08-2017, 11:50 AM   #8
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
Popping is pretty normal with most weight distribution hitches. Makes my wife's skin crawl.
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 02-08-2017, 12:22 PM   #9
SSquared's Avatar
Longmont , Colorado
I have never seen one of those in person. They seem pretty slick. On the Camco web page, I notice that they claim the product has "reduced noise". Not "eliminated". So you should expect some noise.
The product has a way to turn off sway control. Did your dealer explain that to you? You could try turning it off while doing some tight maneuvers in a parking lot to see if the noise goes away. It that cures the noise, that means the noise comes from the sway control and the rest of the hitch is OK. I'm not sure, but I would expect the sway control to be noisy (friction-type sway controls are usually noisy)
Old 02-08-2017, 12:48 PM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Ditto m.hony's advice. I have an Equal-I-zer and without grease it could get me banned from most campgrounds as a nuisance. Read your manufacturer's info on where it can be greased to make sure you don't interfere with the function. They may even sell pads like equalizer does to allow proper but quiet operation.
GammaDog is offline   Reply With Quote
Old 02-08-2017, 02:07 PM   #11
dlenloe's Avatar
Tomball , Texas
Yes, the dealer did explain how to turn off the sway bars mechanism. Will try that. Thanks so much for your input.
Old 02-08-2017, 02:09 PM   #12
dlenloe's Avatar
Tomball , Texas
I do not know if pads are available for the Recurve but I will certainly look into that. I do appreciate your info.
Old 02-08-2017, 02:17 PM   #13
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Mine too, but they work!
MelGoddard is offline   Reply With Quote
Old 02-08-2017, 02:18 PM   #14
short suff
2016 16' Sport
Gallatin , Tennessee
Have you tried lubricating the ball and where the bars attach to the hitch? Mine did the same thing when I picked mine up and scared me and my wife to death. I got out and lubed it up and it went away. Good luck I hope this will solve the problem
short stuff is offline   Reply With Quote
HItch ball height via AS and via Leveling mefly2 Hitches, Couplers & Balls 5 03-13-2012 01:56 PM
Adjusted the ball and hitch today Lucky Dog Hitches, Couplers & Balls 15 03-30-2011 11:03 AM
Popping Rivets and Microwave Question Tylertexan 2005 and newer - Bambi all models 2 08-28-2008 04:48 AM
popping fuse on tow vehicle Stefrobrts Tow Vehicles 14 07-07-2004 01:43 PM
