I have a chevy avalanche...when I connect the hitch the auto leveling pump engages and levels out the truck. How does this effect the towability of the AS and TV and the weight distributing hitch. Any insight? Thanks, Randy
You can install a "in line" switch to disable the compressor.
If you do that, you should also install a "air pressure gauge" to monitor the air pressure, to make sure that the air bags or air shocks are at minimum pressure.
That would also require a "bleed off valve," so that the air pressure can be reduced to the minimum.
If you do the above three items, your tow vehcile air ride system will not interfer with the load equalizing hitch.
If you do not wish to do all three, then don't bother with any of them.
I need to amend my response. While I believe it is correct for vehicles with steel springs and air shocks, the GM system is in fact an "air ride" as someone else noted. There are no separate springs.
The best way to set up the hitch in this case would be to take the whole works to a scale to determine how much tension is really needed. Basically, you would be looking for front and rear axle loading to be relatively equal, and within GAWR limits. Consider that this is not a stiffly sprung pickup, which might be OK with more weight on the rear axle.
I was going to stay out of this, but, I believe Albertf and 2air have gotten this back on track.
No-one on the GM side of the shop could tell me what the standard suspension is for this truck. (They're Buick guys). A quick check on Alldata found at least two types of rear suspension.
You've got to find out what you've got, check the owners manual to see if there's any set up procedure and, if not available, call GM customer service to see if they have any input.
My Ford has air suspension, no metal springs. They call for measuring ride height front and rear on the TV. Turn off the air. Set the WD bars until the ride is within 1/2 inch of the original measurement. Turn the air back on.
This works just fine pulling the GT.
I can envision problems that might occur with a TV load-levelling system and a weight-distributing hitch - but I sure would like to see an authoritaritive presentation of the dynamics involved. I'm sure that I'm not the only one! Now, if someone can just find a source-----
AutoRide is actually 2 separate systems, depending on whether a 1500 or 2500. On the 1500 models, AutoRide uses an onboard compressor with air shocks to help level the rear when under a load. There are procedures in the owners manual for hitching with a weight distributing (WD) hitch on Suburbans that have the AutoRide option. The compressor can be a few hundred $$ to repair if it goes out.
On the 2500 models, AutoRide is a real-time damping (RTD) system, controlled by a separate ride control computer (RCC). Special shocks are used with a ferrous fluid that changes viscosity when an electric current is applied. There is a ride height sensor at each wheel that measures suspension travel, in turn providing input to the RCC that varies the current sent to each shock to stiffen/soften them as needed to optimize the ride. This happens something on the order of 100 times per second. Note that NO leveling function is provided by AutoRide on the 2500.
The AutoRide on the 2500 Suburbans is optional with the 6.0L but was a "mandatory" option with the 8.1L, so ALL 2500 Suburbans with the 8.1L will have AutoRide.
Hello Everyone. I am considering the purchase of a new AS, so I've been trying to figure out exactly what my truck has on it (a 2004 Avalanche Z66). I can't seem to figure it out even by talking to the guys in the dealerships. When I first bought the truck I noticed a reference to air ride suspension and checked it out. I left with the impression that early Avalanches had true air ride suspensions with air bags and compressors. Mine, on the other hand only had special rear shocks that leveled out after a bit of driving. They were part of the Z66 Premium-Ride Suspension package. More recently, by acquiring a copy of the build sheet for the truck, I found out it has the Z82 trailering suspension to go with the HD trailering package. I now assume that the Premium Ride shocks were replaced by the HD suspension components, but the dealer can't tell me if that's the case. I've e-mailed chevy about it, but no response so far. Any idea how I can sort this out? I'd like to know exactly what I have to work with before I buy the trailer.
Thanks for all of the imput. When the dealer set up the system the key was off in the TV. Both the TV and the AS were level with final adjustment. When I turn on the ignition the auto level runs for just a moment. On my next adventure I will pull the fuse and see what the result is. Great idea HowieE. Again thanks to all.
We tow a 25FB with an '05 2500 Suburban with Quadrasteer. All Quadrasteer Suburbans are 2500's and have Autoride. We have almost 30,000 miles with this TT/TV combo. We have never noticed any illeffect from the Autoride.
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Based on a 10 year plus study by the old insurance division of Airstream, (2/3) two thirds of all loss of control accidents, were caused by tow vehicle rear end modifications.
That list included, amoung other things, air shocks improperly inflated, air bags improperly inflated, Monroe load levelers, overload springs, and automatic inflation systems.
The automatic inflation system is about the # 1 killer of the purpose of a load equalizing hitch.
It destroys the proper shifting of weight.
Unfortuantely, just because the trailer and tow vehicle are level, is no sign of proper load eqauliziation.
The automatic level control rear suspension is available
on C/K 1500 vehicles and comes as a part of the
Autoride™ suspension, if equipped.
This type of level control is fully automatic and will
provide a better leveled riding position as well as better
handling under a variety of passenger and loading
conditions. An air compressor connected to the rear
shocks will raise or lower the rear of the vehicle
to maintain proper vehicle height. The system is
activated when the ignition key is turned to RUN and
will automatically adjust vehicle height thereafter.
The system may exhaust (lower vehicle height) for
up to ten minutes after the ignition key has been turned
off. You may hear the air compressor operating when
the height is being adjusted.
If a self-equalizing hitch is being used, it is
recommended to allow the shocks to inflate, thereby
leveling the vehicle prior to adjusting the hitch.
Autoride™
If equipped, the Autoride™ feature will provide a
superior vehicle ride and handling under a variety of
passenger and loading conditions.
The system is fully automatic and uses a computer
controller to continuously monitor vehicle speed, wheel
to body position, lift/dive and steering position of the
vehicle. The controller then sends signals to each shock
absorber to independently adjust the damping level to
provide the optimum vehicle ride.
Autoride™ also interacts with the tow/haul switch that,
when engaged, will provide additional control of the
shock absorbers. This additional control results in better
ride and handling characteristics when the vehicle is
loaded or towing a trailer. See
Tow/Haul Mode Light on
page 3-54 for more information.
4-64
Life is Good-Camping all around New England
