Old 07-24-2009, 01:40 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Attaching Sway Bar to Tongue
My 71 has a sway control bar welded to the tongue. The problem is PO had it put in the wrong dang spot making tight turns a problem. From what I have read/heard the bar type sway controls are pretty standard. The center of the sway control ball is supposed to be 24" from the center of the tow ball. I am a couple of inches shy. The current sway contol ball is welded to a plate which is welded to the tongue.
My 71 is one of those Beatrice years Airstreams with the lighter frame.
My questions are:
a. Can I safely drill holes in the tongue to bolt on another ball?
b. Should I take it to a shop and have it welded?
c. Anybody suggest a good plan c?
Old 07-24-2009, 02:25 PM   #2
My questions are:
Take it to a good welding shop.
They can cut the old ball off, without damaging the A-frame.
Then have them weld it where you want it.
You have a :friction type" sway control.
Are you aware that if your towing in rain or snow, that you must take it off, or back way off the adjustment? If not, you can have a problem when making lane changes.
Old 07-24-2009, 02:46 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
You can use self drilling screws to mount bracket.I always lined up trailer & truck,figured out where 1/2 of the sway bar was ,and that`s where I mounted ball to frame.Dave
easyride is offline   Reply With Quote
Old 07-24-2009, 03:05 PM   #4
Kevin245's Avatar
Both of mine are attached with self-tapping screws. The tongue tube on my 76 is 3/16" tubing which is fairly substantial.
Will you need to remove the existing ball mount to attach the new one?
Regards,
Kevin
Eleanor Roosevelt
Old 07-24-2009, 04:50 PM   #5
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Most people using them ARE NOT aware of this fact. Makes them just about as useless as an ice chest in an igloo.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 07-24-2009, 05:03 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
I just noticed in my original post I stated the "sway control bar is welded to the tongue" What I meant to says the sway control ball is welded to the tongue. Looks like in the above posts they figured it out.
Nevermind what I say, you know what I mean.
Yeah, I heard about that lighten up on the sway control on slippery roads. Also take off the sway control bar when backing because if you back into a jacknife position you can force the bar beyond its limits. Been there done that.
Old 07-24-2009, 05:27 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
As a plan C, why not switch to far simpler classic Dual Cam Sway Control that mounts with U-Bolts? It won't take much labor or additional parts to push toward the cost of a new classic Dual Cam Sway Control.
Kevin
Kevin D. Allen
AIR #827
Old 07-24-2009, 05:45 PM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Kevin
I would like to convert mine to a dual cam, but I have the straight bars and they would need to be replaced as well. I was wondering if this setup would work. It has a piece that bolts on the arms to make it work like a newer arm.
Draw-Tite Dual Cam Sway Control Fits 4 inch and 5 inch Trailer Frames 26000#
Richard
Old 07-24-2009, 06:06 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
I should have mentioned what I have for a hitch. I have an almost new Husky WD hitch mated to an Air Safe class 5 hitch. I want to keep this for a while. My guess is the Draw Tite Dual Cam Sway control won't work easily with this combination and I would need at least a new WD hitch. Right?
I also have a generic friction sway bar and an older Reese friction sway bar.
Old 07-24-2009, 06:13 PM   #10
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Richard!
That is part of the beauty of the classic Dual Cam Sway Control -- it works with almost any existing weight distribution spring bars -- flat-rectagular, flat-square, or round. The saddle attachment just bolts into the same two holes that the chain currently uses for mounting. This is the setup that I use with both of my coaches and both of my tow vehicles.
Kevin
Kevin D. Allen
AIR #827
Old 07-24-2009, 06:13 PM   #11
2002 25' Safari
Dewey , Arizona
Images: 62
The friction ball I installed several years ago to my TW is attached to a plate which bolts onto the frame. I drilled 6 holes in the frame and installed the screws. I don't think the frame is any weaker because of this.
Richard
Old 07-24-2009, 06:24 PM   #12
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Lumatic!
The answer to whether the Dual Cam Sway Control will work with your Husky hitch depends to a degree upon which of the Husky weight distributing hitches that you have.
  • If yours is the "Centerline System", you already have a hitch with sway control that functions in a similar manner to the Dual Cam System.
  • If yours is the "Round Bar or Trunion" weight distributing hitch, the classic Dual Cam Sway Control should work with your existing weight distribution bars -- it just bolts on as a direct replacement to the chains.
This classic Dual Cam Sway Control System is the one that I use with both of my trailers and both of my tow vehicles.
Kevin
Kevin D. Allen
AIR #827
Old 07-24-2009, 07:05 PM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
Greetings Lumatic!
Kevin
I've got the square trunion bars with the chains.
I wonder if the Dual Cam system is more sway control than I need for my 25' 4500# Tradewind?
Old 07-24-2009, 07:15 PM   #14
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Lumatic!
Dual Cam Sway Control works with any trailer that has at least 400 pounds of tongue weight according to what the technician from the engineering department told me when I inquired before installing it on my Minuet 6.0 Metre. Most of the Airstreams since 1965 as well as most of the Argosy coaches easily meet the 400 pound hitch weight requirement when they are loaded for an excursion.
Kevin
Kevin D. Allen
AIR #827
Sway bar help Diana Langley Hitches, Couplers & Balls 13 06-10-2008 05:02 PM
New Sway Bar or Just New Bushings? streamlean General Motorhome Topics 48 09-25-2007 10:12 PM
Sway Bar Bushing Search 911rs Argosy Motorhomes 13 07-12-2007 11:45 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
How essential is the sway bar? 63overlander Hitches, Couplers & Balls 25 11-03-2004 06:11 AM
