Old 12-17-2008, 05:10 PM   #1
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
AS Security. Hitch lock or More
So I have the normal hitch padlock that could be overcome in less time than I can say overcome. So has anyone got some good ideas on how to defeat at least the casual AS thief?
This thought came because of ou foram friend who has resently had their beutiful AS taken from them.
man7sell is offline   Reply With Quote
Old 12-17-2008, 05:26 PM   #2
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
I think one should employ several methods to protect their trailers. Someone mentioned this in the thread about the trailer stolen in Seattle.Overton's - Gorilla Guard Trailer Lock
This is one of the things I have done.
safari62 is offline   Reply With Quote
Old 12-17-2008, 05:47 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
safari62 that would definately slow someone down, as long as you don't have a front or rear mount spare tire without a lock
We have one security measure mentioned awhile back that in the event someone is reading the threads and shopping for trailers I won't mention, but we're in the process of adding GPS tracking systems in both our trailers. We're going to be putting in this:
Anti Theft Device for Stolen Vehicle Recovery - Smart Track by Rocky Mountain Tracking
well hidden, with the external antenna and a back up power source in case they disconnect the battery to avoid any alarm system. At least with hitch locks, padlocks, good lighting/security we can likely track the trailer if it is taken, and only pay as you access the tracking info instead of monthly membership fees.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Old 12-17-2008, 06:13 PM   #4
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I like the idea of a GPS tracking system.
I supply the thieves with only the back bumper of the Safari if they have a mind to tow it off. I can drive into my driveway frontwards, unhook, and just barely have room to drive my pickup through the yard, around the barn, under the clothesline, by the house and back out to the driveway. The trailer won't fit that way, so I have to back the pickup back through the "maze" to hook up and back the trailer out of the driveway. The thieves would have to have a lot of guts to try that routine and besides, my back-up system is a 12 gauge shotgun along with two driveway use alert alarms.
Sam
samb is offline   Reply With Quote
Old 12-17-2008, 07:11 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Tires Dragging
I've been looking at adding a second brakeaway switch, hidden under the frame connected with a fine strong wire to a tent peg in the ground, under the trailer. If the trailer is moved the brakes will come full on and make it very hard to drag the trailer away. What do you think?
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 12-17-2008, 07:34 PM   #6
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
If there is no electrical power, will the switch still work? Electric brakes need electricity to operate, isn't that correct? I don't know how the brake-a-way stitch works. I do know that if the trailer come off the TV then the brake-a-way switch will cause the brakes to lock. What happens if the plug is also pulled out?
I am not trying to hijack this thread, I just need to know if Shacksman's idea could/would work.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 12-17-2008, 07:39 PM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
After brakes burn out then they can still tow it away.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-17-2008, 07:42 PM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Man, I'm glad I live in a area where I don't have to worry about stuff like this..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 12-17-2008, 07:53 PM   #9
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The brakeaway switch works off of the battery. As long as there is a working battery in the trailer it'll work.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 12-17-2008, 08:00 PM   #10
macofpei's Avatar
2003 30' Classic
I think the only way to foil a trailer thief is that thing the police put on your tire to keep you from driving away. A Wheel lock. That or hooking the AS to about 15 amps of electricity.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
Old 12-17-2008, 08:26 PM   #11
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
That would take awile to happen and I don't think they will sit around waiting to see what happens. I'd rather fix the brakes then look for another trailer
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 12-17-2008, 08:33 PM   #12
goransons's Avatar
1963 22' Safari
having towed the overlander about 3 blocks with a locked up wheel, everyone for blocks knew something was going on (that sound preceeding an accident for a lot longer than logical). Not many would keep going drawing that much attention. Those that have the battery inside the trailer would likely have a much easier time with the brakes. As far as battery drain for the trailer battery for a GPS I've heard a small portable solar cell placed in the rear window of the trailer plugged into the 12v outlet provides enough of a charge to replenish what it draws.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 12-17-2008, 08:52 PM   #13
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Images: 43
Yes, I have heard about this before and it should work.
The "hidden" wire would have to be looped through a pulley at least in my case as the pin is now in the direction of the tow vehicle. Then the wire could be fastened to the stake towards the rear under the trailer. As the trailer moves forward the pin is pulled out via the wire and pulley which would send power to the brakes.
Then follow the skid marks.
I like the idea of the lug nut lock if the wheels are off also.
How about a locking device on the front jack....so it cannot be raised?
Old 12-17-2008, 09:02 PM   #14
goransons's Avatar
1963 22' Safari
one of our friends had their flatbed trailer stolen a few years back, the front jack was locked, they took care of it in a few seconds with a battery powered sawzall with a metal blade, and I mean seconds. Cameras caught it, they backed up, two guys lifted the tongue onthe the truck, cut the pipe and away they went.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
security locks
Hitch Lock SilverCabin Hitches, Couplers & Balls 14 09-02-2008 08:59 PM
Security Jenturnr Towing, Tow Vehicles & Hitches 19 12-01-2005 09:05 AM
Security luckydc Our Community 26 06-06-2004 01:50 PM
Security... canny_banjo_man Our Community 14 06-18-2003 03:34 PM
Security lock for the tongue? Diana Langley Hitches, Couplers & Balls 11 11-19-2002 11:01 AM
