Old 11-27-2013, 11:43 PM   #1
San Bernardino , California
AS 22' Sport & Equalizer recommendations
Hello All,
We are buying a AS Sport FB 22 and our purchase will include an Equilizer and brake controller. My TV is a 2009 Tacoma (6500lb capacity and 650lb tongue weight). I dont ever plan on having more than 250lbs on my TV rear axel (in the bed) and my AS has a 396lb tongue rating. Should I get the Equilizer that has the 600lb or 1000lb rated torsion bars? I have heard that using bars that are rated too high (stiff) could be too harsh on my A frame. Any thoughts as to which hitch (600 or 1000) to install? My intuition is use the 600lb.
highdesert03 is offline   Reply With Quote
Old 11-28-2013, 01:16 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have the 1,000 lb bars on my 25'er, but I would use the 600 lb bars with your 22' Sport. [my opinion]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 11-28-2013, 07:40 AM   #3
Thanks. I understand the torsion bar rating should match the tongue weight + weight over the rear axel. My tongue weight (400) + max weight over the rear axel (100-2 00 lbs of cargo) will equal approximately 600lbs.
My concern is 1000 may transfer too much vibration to my A frame and therefore possibly damage it (over time).
Old 11-28-2013, 09:11 AM   #4
K.C. , Missouri
I'm thinking your real world tongue weight is going to be between 550 and 600 pounds, not 400 pounds. Roll it over the scales, packed as ready to camp, to find out what the real weights are.
gmw photos is offline   Reply With Quote
Old 11-28-2013, 09:39 AM   #5
So if we are over 600 pounds let's say by 50 to 100 would we necessarily be better with 1000 bars? Seems excessive to me to go up to 1000 bars for what could be 16% overage in weight for the 600 lb bars.
Old 11-28-2013, 10:00 AM   #6
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I just listened to episode 196 of The VAP. Very informative and some well elucidated opinions on WD hitches. I've eschewed them before, now I'm definitely considering. You might want to listen to this before you buy
DryFly is offline   Reply With Quote
Old 11-28-2013, 11:30 AM   #7
Just listened to a good portion of the podcast. Very informative. Learned that for my application (my truck has a short wheel base) the distance the load weight would need to travel to redistribute the weight to the front axel is minimal in terms of distance. I infer that I can use a 600lb rated bar with less concern because of this. If I had a larger TV with a longer wheel base than a higher rated bar (1000) might be preferable. Thanks for the podcast tip.
Old 11-28-2013, 02:18 PM   #8
K.C. , Missouri
Well, we keep hearing over and over from guys like Inland Andy that Airstreams "like a soft ride", so I am thinking that your idea of 600 pound bars sounds more logical than 1000 pound bars. My main thought in pointing out that your tongue is likely to weigh more than you originally thought is that advertised weights vs real world weights can sometimes be quite different.
Just as a point of reference, BlueOx offers bars in 350, 550, 750 and then on up from there, if I remember correctly.
Old 11-28-2013, 04:27 PM   #9
Thanks for pointing out the real world difference for tongue wts. I'm sure you are right about it easily weighing more than its specs. I suspect I'm going to be good at 600lbs because I don't see myself packing more than 100 lbs in my bed (food, drinks, misc stuff). We plan on short excursions to the beaches of So Cal.
Old 11-30-2013, 02:09 PM   #10
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
We used the 1000/10000 load bars with our FC20 and saw no signs of vibration issues. It is too bad that EQ does not allow easy load bar changes between the various ratings of the heads .... good place for an after-market adapter!
We chose those load bars to allow for "future" TT changes and now find them great for our 25 EB.
Old 11-30-2013, 02:48 PM   #11
K.C. , Missouri
Originally Posted by mefly2 View Post
........snip.....
From the for what it's worth department, BlueOx does exactly that with their swaypro: the head is the same, and you can choose bars rated for 350, 550, 750, 1000, 1500, 2000
Old 12-01-2013, 06:26 AM   #12
tkowalyk's Avatar
2013 27' FB Classic
Clermont , Florida
Images: 11
Hello All, We are buying a AS Sport FB 22 and our purchase will include an Equilizer and brake controller. My TV is a 2009 Tacoma (6500lb capacity and 650lb tongue weight). I dont ever plan on having more than 250lbs on my TV rear axel (in the bed) and my AS has a 396lb tongue rating. Should I get the Equilizer that has the 600lb or 1000lb rated torsion bars? I have heard that using bars that are rated too high (stiff) could be too harsh on my A frame. Any thoughts as to which hitch (600 or 1000) to install? My intuition is use the 600lb.
The equalizer ride (even with the 600lbs bars) would be way too rough. I speaking from experience. I had an equalizer with 1000 lb bars for my 25 Safari, and the connection was very ridged and we had a lot of movement of cargo inside the the trailer. After a couple of years, we switched to the Reese dual cam with 800lb bars. The ride and handling was much improved. Fast forward to this year, and when we bought out 27 Classic, we kept the Reese dual cam. With minor modifications - taking up another chain link, and adjusting the cam, she tows like a dream.
Regards,
Tom
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
2011 4Runner 4x4 pulling 16ft Sport? gerhard Tow Vehicles 12 04-17-2012 05:59 AM
New member looking for 16 ft Sport info Rich of SCal Member Introductions 19 01-05-2012 12:43 PM
Hitch advice - Safari Sport 22 nesvt Hitches, Couplers & Balls 17 12-16-2011 04:50 PM
Airstream Sport 22 :: 2011 Airstream Sport Lone Eagle0 Airstream Registry Discussions 0 08-19-2011 08:32 AM
2010/2011 Sport 22 FB Questions smeghead Member Introductions 16 02-10-2011 10:09 AM
