Old 05-12-2011, 07:16 PM   #1
Cairo , Georgia
Arrow vs 3P...?
I'm trying to compare the arrow with the 3p hitch, I've spoke with both companies and read many comments on each. Has anyone out there given up one for the other or willing to post mechanical problems with either? Unlevel hitching is not one of my concerns. Thanks to all replies.
bugsnacher is offline   Reply With Quote
Old 05-12-2011, 07:28 PM   #2
SteveH's Avatar
Common Sense , Texas
There are extended threads on each hitch in the hitch section of the forums.
I have no experince with the Hensley, but I do have the ProPride, have no problems, and would not be without it. When I decided to by this type hitch, I figured I'd get the latest and best version of the design.
Regards,
Steve
Old 05-12-2011, 07:57 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
There are several threads on this exact question. You may want to do a search using Hensley and Pro Pride or 3P as search terms. This thread may be helpful as well.
http://www.airforums.com/forums/f464...-3p-51958.html
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 05-12-2011, 08:14 PM   #4
Dwight's Avatar
1999 34' Excella
Joshua , Texas
I have had several trailers and each one had the Hensley.....I like the design, function and ability to adjust for wear in the hitch....never had a problem with their customer service either....
Never have owned the Pro-Pride so I can't comment one way or the other....
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-13-2011, 08:41 AM   #5
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
The thread with the most direct comparisons is here...
http://www.airforums.com/forums/f464...e-57179-2.html
You'll find comparison pictures and comments from customers who have owned BOTH hitches.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 05-13-2011, 09:41 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Bugsnacher
2airishuman switched from the Hensley to the 3P on his trailer and was pleased with the switch. I believe he is the only one who has done so although there are other people who have had the Hensley on one trailer and the 3P on another.
I have the 3P.
Both hitches work as designed. The differences are minor:
1) 3P has a larger opening for the stinger which makes it a little easier to hitch up
2) On the 3P the stinger drop is adjustable. While Hensley offers free exchanges to the original purchaser, round trip shipping is typically $75. If you are not the original purchaser you have to buy a new stinger which is around $250 including shipping.
3) The Hensley uses the grease zerks as part of the retention mechanism for the WD bars, and they're prone to failure. 3P uses a separate retainer sleeve which works better
4) The orange paint on the Hensley fades in the sun and looks bad after a year or two.
You might also search around for comments from people who have needed repairs or parts for their Hensley hitch, either in or out of warranty. Such comments have not been uniformly positive.
Old 05-21-2011, 11:20 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
ProPride is an infamously excellent hitch designed by Jim Hensley with the best service and support one could ask for.
Do the research - you will come to your own conclusion, obviously for me - it is an invaluable part of my overall tow package and I would't even think of using another hitch.
ProPride - money well spent - designed by the best and backed by the best.
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Adjustable Hensley stinger dmcummins Hitches, Couplers & Balls 31 03-23-2018 08:53 AM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Towing 2011 Classic 34 With Chev Duramax RV Doctor Tow Vehicles 13 04-17-2011 10:21 PM
Rear light housing seal--how? OB Bambi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2011 04:33 PM
