Old 11-14-2013, 06:20 PM   #57
reinergirl's Avatar
Hollis , New Hampshire
There's a good discussion of weight distribution and other hitch related items on the latest episode of The Vintage Airstream Podcast | Vintage Trailer Restoration
reinergirl is offline   Reply With Quote
Old 11-14-2013, 06:30 PM   #58
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Weighty Discussion "WD"
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-14-2013, 06:32 PM   #59
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thanks, Poppy. Good idea - looking it up :-)
Here's Google's definition of ideal as an adjective:
satisfying one's conception of what is perfect; most suitable
So if your Blue Ox restores your tow vehicle's requirement for front axle load replacement (I forget, does your MB even allow for WD?? ), it is adequate. Only you can decide if that is ideal. :-)
There's another definition of ideal that's close to impossible to attain. Like, ideally, Airstream would give trailers to its customers at no cost. :-)
Putting all the definitions together:
I love the ProPride. It is both adequate for WD and ideal (for me) in terms of preventing sway rather than reacting to it after the fact. AND, ideally, it would weigh 25 lbs and cost $100. :-)
On ideals - everyone's mileage varies. On adequacy, I think you've got a working definition to make that call.
Good luck!
Old 11-14-2013, 07:54 PM   #60
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I suspect most would consider "adequate" an unacceptable goal for connecting their Airstream to a tow vehicle. It's a safety issue worthy of a higher standard.
Doug and Cheryl
Old 11-24-2013, 09:51 AM   #61
Harlingen , Texas
Adequacy of the hitch is linked to the adequacy of the tow vehicle (pun intended). A late model GM 2500HD is rated by GM to tow over 15,000 pounds with no Weight Distributing hitch, so any or none will be adequate. Even the most expensive hitch will not make a light duty passenger vehicle tow nearly as well. (advertising to the contrary) It is the whole package, not just the hitch, tow vehicle, or trailer.
Rendrag is offline   Reply With Quote
Old 11-26-2013, 10:13 AM   #62
Navarre , Florida
Have this same question, though more of brand reccomendation. I used to pull a Starcraft 28fb and the hitch was the most basic WD hitch available ; both of the chain tensionsers bent though fatigue, and I do not want that type of set-up again. Considering I'm towing with a 3500 (that will have this setup on it when we start camping more https://kelderman.com/dodge_ram_2003...air_suspension) a WD hitch is not top priority, but a good sway control might be, and would prefer one that is part of the hitch, not an add-on.
2006 Salem LE Sport 32SRV Toy Hauler
2008 Ram 3500 Laramie 4x4 QCLB SRW
norfla71 is offline   Reply With Quote
Old 11-30-2013, 02:43 PM   #63
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by RickDavis View Post
I don't know how long the WD hitch has been around, but I know they were in common usage 40 years ago when a lot of towing was still done with large cars.
Many variables involved , but regarding the hitch itself stick to name brand products. Most of the makers have been around a number of years and probably would have been sued out of existence if they made a dangerous product.
Beyond that absorb all the varied opinions you see and make a decision based on your needs and what you are comfortable with.
I welded them on for local TT users in the 1960s ...
