Old 11-26-2012, 04:54 AM   #15
2005 28' Safari
saline , Michigan
Has anyone considered moving the tongue jack?
Kosm1o is offline   Reply With Quote
Old 11-26-2012, 07:29 AM   #16
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by REDNAX View Post
... There are alternatives to "tailgates" (bed access) from several directions.
Would a tailgate designed for 5th wheel applications, the one with a V notch in the middle work in this situation?
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 11-26-2012, 07:34 AM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Great minds, and all that… Silver Goose beat me to it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-26-2012, 08:20 AM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Originally Posted by adwriter73 View Post
Need to pull with the tailgate down on truck and there's not enough clearance between it and the lift jack on the Airstream. Was wondering about a 8" hitch receiver extender but I am afraid of compromising the tongue weight and towing capacity and overall safety. Anyone have experience with this?
I don't think that towing with the tailgate down is a good idea. Even if you had enough room to lower the tailgate past the jack you will have a very limited turn radius and could easily push the tailgate into the front of the trailer.
Richard
Old 11-26-2012, 08:28 AM   #19
I don't think he intends to tow with the tailgate down. More likely, just load/unload the pickup bed without unhitching first.
WBCCI #1105
TAC LA-4
Old 11-26-2012, 08:30 AM   #20
2002 25' Safari
Dewey , Arizona
Images: 62
In the original post it states: "Need to pull with the tailgate down on truck".
Richard
Old 11-26-2012, 08:35 AM   #21
Duh! Missed that. In that case, I agree. Never a good idea to tow with the tailgate down.
WBCCI #1105
TAC LA-4
Old 11-26-2012, 11:30 AM   #22
LFM
LFM's Avatar
2007 19' Safari SE
Laurel , Montana
I have the short box on my crew cab Ecoboost. If I added 6-8 inches to a hitch, wouldn't it still be closer to the rear axles than on a long bed?
LFM is offline   Reply With Quote
Old 11-26-2012, 12:34 PM   #23
Naper's Avatar
Loretto , Ontario
I think you will find the wheel base is longer on the 6.5' box truck not the overhang
Naper is offline   Reply With Quote
Old 11-26-2012, 01:06 PM   #24
F150 supercab ecoboost comes with three box lengths, according to the Ford F150 website:
5.5' box = 133.3-inch wheelbase;
6.5' box = 144.5-inch wheelbase (12-inch longer box and 11-inch longer wheelbase than the 5.5);
8.0' box = 163.1-inch wheelbase (18-inch longer box and 19-inch longer wheelbase than the 6.5).
Longer box means longer wheelbase, but not a longer distance from the rear axle to the hitch. So, no, an extension hitch doesn't equate to a longer box in terms of vehicle geometry.
Here's a comparison for you: The Airstream Interstate has a rated towing capacity of 7500 pounds. The 2013 Extended version, however, is only 16 inches longer (all behind the rear axle), but has the rated towing capacity reduced to only 5000 pounds, for exactly the same hitch receiver. And this is on a vehicle with a 170-inch wheelbase.
No one can stop you from using an extension if you really want to, but you will lose towing capacity if you do. And you'll need longer safety chains, longer wiring to plug in your trailer, and probably some other modifications to either the trailer or the tow venicle.
WBCCI #1105
TAC LA-4
Old 11-26-2012, 01:13 PM   #25
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Take look at Blue Ox Blue Ox - Weight Distribution
I use the longer shank and my tail gate clears the elect. jack. Works great! I'm only pulling a 22' Safari.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 11-26-2012, 01:42 PM   #26
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
It's all about leverage. The further you put the ball from the rear axle, the more leverage will be applied to that axle. Trailer and TV handling will be adversely affected; it's simple physics. Of course, we all trade things off to get what we want, in this case a working tailgate, so if your TV can cope with the extra load then I guess you go for that extension, but it won't work as well as if you have the shorter shank.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
