Old 05-07-2010, 07:53 AM   #15
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Buttons
My questions is why would you want one of these?
I don't see it being any advantage except in a very unusual set of circumstances.
What does your Cargo trailer weigh and what are you towing it with? Which hitch system are you currently using?
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 05-07-2010, 08:08 AM   #16
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You would need to use the equalizer bars because the hitch ball is behind the axel. Without the bars, the trailer tongue would push the rear of the slimp wheel down and the unit wouldn't be level enough to hitch up to the TV..
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 10-24-2012, 01:58 PM   #17
1981 31' Excella II
New Market , Alabama
The hitch does not fix the too much mass for the tow vehicle problem. You could tow a trailer with a Mini Cooper but why would you want to unless you live in Canada. I guess if you had an old 70's caddy with bad springs it might be helpful.
Perry
Old 10-24-2012, 02:16 PM   #18
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Numbers, numbers, we must have numbers. Just kidding I don't need any stinking numbers.
MICHAEL
Old 10-24-2012, 03:22 PM   #19
Wise Elder
Jammer's Avatar
2010 30' Classic
These pose stability problems in many situations. I don't think they're safe.
Old 10-24-2012, 03:57 PM   #20
r carl's Avatar
Lin , Ne
Until you get rid of the white SOB type fenders and install aluminum ones it wont work for an airstream.
Old 10-24-2012, 04:54 PM   #21
Denis4x4's Avatar
Durango , Colorado
There's something similar that allows motorhomes to tow gooseneck horse trailers.
Denis4x4 is offline   Reply With Quote
Old 10-25-2012, 06:56 AM   #22
1981 31' Excella II
Are these folks using load distributing hitches who are having all these structural problems? Just about every day I see lawn and construction trailers being pulled by an old van and the thing is dragging the ground because there is no load distribution. Your device would help them out. However, a load distributing hitch evens out the load on all 4 wheels which is going to improve traction and braking.
Perry
Old 10-25-2012, 08:54 AM   #23
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Here is a glimpse of was called in 1952 as a 'dolly'. It was a pair of wheels on an axle with leaf springs. The trailer hitched to a ball on top of the springs and the unit hitched to the car hitch. This is the same principle as tanden trailer combo on big rigs. Vertually impossible to back up your trailer. Dad was forced to buy this setup in Abilene in 1952 while towing a 26' travel trailer with a '48 Nash on our move from Michigan to California then. I was 14 in this photo and my 'job' was to connect and un hitch our rig. Another version was called a slimp wheel, a wheel under the hitch that swiveled. It was too pricey for my parents then.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 10-26-2012, 03:36 PM   #24
Washougal , Washington
There used to be a company making 5th-wheel hitches called "Hitch-Buddy". Those would allow you to tow a fiver with a standard, "unmodified" (no hitch in the bed) pickup truck.
Here's a photo...
These same guys were advertising a dolly like the one in "The Long, Long Trailer". They're gone, now...
Steamguy is offline   Reply With Quote
Old 10-26-2012, 07:57 PM   #25
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
C Train
This concept is used commercially where required by law and is known as a "C Train Dolly".
"The 'C-Train' is similar to an A-Train except that two drawbars are used to eliminate the freedom to rotate about a vertical axis at the hitch point. The dolly is equipped with a self centering, self steering axle that requires a side force of about 0.3g to steer. Canadian regulations allow slightly higher loads on C-Trains than A-Trains."
mty40.htm, DOUBLES: A-Train, B-Train, C-Train; Tractor towing two Trailers
Some of these dollys have a steering axle and some are solid. (depends on the length of the drawbars, the application, and the jurisdiction rules.)
The "C Train" was an attempt to eliminate one vertical pivot point on a multi trailer application thus making it somewhat more stable. Many "A Trains" were converted to "C Trains" to take advantage of the more generous GCVW's allowed.
There should be no reason that this concept would not work on a RV application, IF THE TOW UNIT HAD SUFFICIENT FRAME ABILITY TO HANDLE THE STRESS.
I doubt any pickup or 3/4 ton equipped from the factory would qualify. The distance between the drive axle and the hitch dolly would be an excessive ratio verses the weight of the towing vehicle.
Dave
Old 10-26-2012, 09:24 PM   #26
1973 Argosy 24
Evanston , Wyoming
Look at a "Trailer Toad" it's close to your photo
twinkieman is offline   Reply With Quote
Old 10-27-2012, 12:43 AM   #27
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Perry
Not sure what the jab re Canada means in this post? Care to explain?
George
gandttimes is offline   Reply With Quote
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Need Help With Hitch InspectorDread Hitches, Couplers & Balls 5 12-03-2006 07:37 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
What hitch is this? Rog0525 Hitches, Couplers & Balls 2 04-12-2004 06:23 PM
